![]() | Home > Technical (L322) > Intermittent Chirp - how do I fix? |
Wenners Member Since: 10 Dec 2015 Location: Warwick Posts: 26 ![]() ![]() ![]() |
Any suggestions welcome!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 ![]() ![]() |
have you done a search? ... - .- -.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7948 ![]() ![]() ![]() |
Not able to resist a search challenge - here |
i hear theres a new search browser,
Yes I do do a search and came up with the same result as Alistair but that contains sassiest acne in fixing the problem, was hoping someone had fixed the problem and can let me know how?
Think of it as an opportunity |
Looks like my spell check got the better of my last post, am not under the influence!
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 ![]() ![]() |
My previous 2011 vogue had a chirp on Tick over from new - the dealer swore there was nothing wrong with it....
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 809 ![]() ![]() |
I get the chirping about 20 miles into a motorway drive. Regular it is.
This one is while its parked up, once every few hours. |
6029 king Stephen Member Since: 11 Apr 2015 Location: Sittingbourne, Kent Posts: 101 ![]() ![]() ![]() |
If by a chirp you mean an irritating high pitched noise similar to that on the old BBC test card, then yes I have the same problem. When I was in the UK in February I visited a dealership to find out if they knew what it was but they drew a blank. I have recorded the noise which can be heard when coming down to unlock the vehicle and there is no key in the ignition. Sometimes it stops when the engine starts and at other times, it continues for about 15-20 minutes before stopping. It has also started and finished whilst out driving it.
SCPB Member Since: 16 Jun 2015 Location: Surrey Posts: 72 ![]() ![]() ![]() |
My 2010 range rover has just started doing exactly the same. It is a shrill, short, chirp noise of a second or less, but it seems to do it regularly every few hours. As the car is parked in the garage, I don't always hear it, but when I do, it always seems to be at half past the hour! It has scared the life out of me a couple of times when I was in the garage and it made the noise.
Sleeper Member Since: 01 Jun 2016 Location: Birmingham Posts: 55 ![]() ![]() ![]() |
Only chirping i got (stopped for new) was from inside the engine bay, could hear it inside the car.
