Home > Technical (L322) > Intermittent Chirp - how do I fix?
Wenners
United Kingdom 2009 Range Rover Vogue SE TDV8 Zermatt Silver
[img]My 2010 MY makes a chirping noise every few hours.
I have read another post on here where it was suggested that it could be the back up battery for the alarm, it certainly sounds like it could be from the alarm but how do I fix it?
Ps suspecting the car battery was at fault I had it tested and was told it was fine.[/img]
Post #385445 5th May 2016 9:32pm
Wenners
Any suggestions welcome!
Has anyone else sorted this?
Thank you
Post #385497 6th May 2016 8:03am
have you done a search? ... - .- -.
Post #385500 6th May 2016 8:15am
Not able to resist a search challenge - here Very Happy
I'm too easily distracted from what I'm supposed to be doing Embarassed
Post #385502 6th May 2016 8:33am
i hear theres a new search browser,
Mr. Green ... - .- -.
Post #385506 6th May 2016 9:10am
Rolling with laughter Thumbs Up
Post #385507 6th May 2016 9:12am
Wenners
Yes I do do a search and came up with the same result as Alistair but that contains sassiest acne in fixing the problem, was hoping someone had fixed the problem and can let me know how?
Is it a case of replacing the siren?
Can the back up battery be replaced in my existing one?
Where is the siren? Is it easy to get at?
Sorry if I'm being a bit thick, every other search I've done usually produces some comprehensive answers.
Thanks again.
Post #385576 6th May 2016 4:51pm
Think of it as an opportunity Whistle
Don't forget to take plenty of photo's & if you're lucky Stan will add it to the Wiki Thumbs Up
Sorry I can't be of any constructive help - I've not heard of that one before - but the linked post does make some sense, that if the car battery is good, it's probably trying to warn you that the alarm backup battery (assuming there is one) is on the way out.
Post #385578 6th May 2016 5:10pm
Wenners
Looks like my spell check got the better of my last post, am not under the influence!
Thanks for looking, will be sure to report back when I find a cure, with photos of course!
Post #385591 6th May 2016 6:14pm
Roystonh
My previous 2011 vogue had a chirp on Tick over from new - the dealer swore there was nothing wrong with it....
I coped with it until it was sold on. So can't help I'm afraid. 2005 L322 Vogue Gold gone
2006 L322 Vogue Black gone
2011 L322 Vogue Silver gone
2011 L322 Autobiography Black gone
2015 L405 Autobiography LWB Black gone
2019 L405 P400e Range Rover Autobiography LWB Eiger grey / black roof gone
2001 P38a 30th Anniversary Wimbledon Green gone
2019 L405 P525 Autobiography LWB British Racing Green
Post #385603 6th May 2016 7:14pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
I get the chirping about 20 miles into a motorway drive. Regular it is.
It's the PDFs regenerating, isn't it.
Very Happy
Post #385622 6th May 2016 8:40pm
Wenners
This one is while its parked up, once every few hours.
Post #385778 7th May 2016 4:18pm
6029 king Stephen
United Kingdom 2008 Range Rover Vogue SE TDV8 Rimini Red
If by a chirp you mean an irritating high pitched noise similar to that on the old BBC test card, then yes I have the same problem. When I was in the UK in February I visited a dealership to find out if they knew what it was but they drew a blank. I have recorded the noise which can be heard when coming down to unlock the vehicle and there is no key in the ignition. Sometimes it stops when the engine starts and at other times, it continues for about 15-20 minutes before stopping. It has also started and finished whilst out driving it.
Regards,
Steve
Post #386279 10th May 2016 10:37pm
SCPB
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
My 2010 range rover has just started doing exactly the same. It is a shrill, short, chirp noise of a second or less, but it seems to do it regularly every few hours. As the car is parked in the garage, I don't always hear it, but when I do, it always seems to be at half past the hour! It has scared the life out of me a couple of times when I was in the garage and it made the noise.
The main battery is fully charged and was replaced less than a year ago.
To try and fault find the problem, tomorrow I will leave the car unlocked and see if it happens then. Does yours only do it when the alarm is on? 2010 5.0 SC Autobiography
Post #394207 2nd Jul 2016 11:48pm
Sleeper
United Kingdom 2003 Range Rover HSE 4.4 V8 Adriatic Blue
Only chirping i got (stopped for new) was from inside the engine bay, could hear it inside the car.
To cut a long story short is was (or still is as done nothing about it) a small fan under the ecu? whixh helps keep it cool.
Bit vague i know but not looked into it further.
Happens when i unlock and sometimes when driving and locking the car, fan carries on for about 10 mins
I believe its warn and the occasional chirp shound is made when spinning.
(drivers side)
And from memory im sure i could hear it though one of the vents or under the dash by the peddles
Hope this helps
Post #394222 3rd Jul 2016 8:56am
