Home > Technical (L322) > Does the 8 speed suffer from juddering like the 6 speed? |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 |
Drove my car today in town and a couple of times it seemed as though it couldn't decide what gear to go in? At the same time got a slight judder . One of my old D3s a few years ago had a very similar problem and a gearbox megaflush cured it and i wondered if anyone had similar issues with the 8 speed
2nd Jul 2016 9:57pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1775 |
The 8 speed is much more difficult to flush, as there is a thermostat in the cooler pipework that doesn't open until 75 degrees C.
2nd Jul 2016 10:05pm |
Cheers Mike, sent you the FB message first . Looks like its just a drain/refill then?. At least some of the oil will be new. Will see how it behaves from now on, and if it does it again i will get some oil and a filter and see if it continues. Have also heard of an ECU flash at dealers for a similar problem so may have to contact my local stealers and ask the question Paul
2nd Jul 2016 10:11pm |
Are you aware of the software update Marsie?
3rd Jul 2016 9:24am |
Hmm, that makes interesting reading . It pretty much describes the fault i have got. I cannot replicate the fault and it doesn't happen every time. Think this may be the way to go at first
3rd Jul 2016 10:05am |
Ok, thanks. Will have a word with my local stealers tomorrow and see what they say. Don't mind paying £100 if it cures it and prolongs the life of the box. Mine has also only done it a couple of times but is alarming when it does
3rd Jul 2016 3:53pm |
Car is going in later this month for a brake hose recall and they are going to have a look at remapping gearbox while its in so will see what happens Paul
5th Jul 2016 4:36pm |
