![]() | Home > Maintenance & Mods (L322) > Discoloured foundry grey trims? |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 ![]() ![]() ![]() |
My car has a matt foundry grey type finish on the grill surround and side vents but it looks patchy and discoloured as though it has has some harsh cleaning products used. Has anyone got any suggestions on how to get them back to original finish, or is it a case of getting them painted? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35656 ![]() ![]() |
peanut butter spread works.. ... - .- -.
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Ah. The Brunel grey trim. More than likely a repaint, there never seems to be a lot of paint on them.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6773 ![]() ![]() ![]() |
That's one of the more unusual uses of peanut butter spread I've heard of recently |
yes, also the door exterior handles. They look stained?? Will try and get some pics but you can see where something has been sprayed on and its stained the finish Never heard of the peanut butter approach ![]() Paul Paul 2014 Range Rover vogue se 4.4sdv8 Loire Blue 1992 Range Rover Vogue LSE 4.2 Ardennes green |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 ![]() ![]() ![]() |
Peanut butter has previously been recommended on the detailing world forum as a means of bringing tired exterior plastic trim back to life.
Wrong topic. |
1959terry Member Since: 28 Apr 2014 Location: London Posts: 128 ![]() ![]() ![]() |
Not used it myself however i heard that teak oil works well. Maybe someone can confirm? 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Peanut butter does work tbh on plastic trim, but it's an expensive route as a proper restorer will be the same once you use it a few times !!
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8555 ![]() ![]() ![]() |
Peanut, or any other oil is a temporary solution to "some" trims, the unpainted grained plastic, the ones the OP is talking about are painted so peanut butter will just make squirrels attack them!!!
Think i may see about colour coding or going black?
