Home > Maintenance & Mods (L322) > Discoloured foundry grey trims?
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
My car has a matt foundry grey type finish on the grill surround and side vents but it looks patchy and discoloured as though it has has some harsh cleaning products used. Has anyone got any suggestions on how to get them back to original finish, or is it a case of getting them painted? Sad
Paul Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #393923 30th Jun 2016 9:22pm
peanut butter spread works.. ... - .- -.
Post #393932 30th Jun 2016 9:58pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Take it you mean the front grill and engine side vents?
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ➞ YouTube.com/RangeRoverOwner
Post #393935 30th Jun 2016 10:10pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Ah. The Brunel grey trim. More than likely a repaint, there never seems to be a lot of paint on them.
did my front grill and got the side vents and bonnet vent to do.
greg
Post #393943 30th Jun 2016 10:22pm
That's one of the more unusual uses of peanut butter spread I've heard of recently Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #393944 30th Jun 2016 10:34pm
marsie
Matt
yes, also the door exterior handles. They look stained?? Will try and get some pics but you can see where something has been sprayed on and its stained the finish
Never heard of the peanut butter approach Rolling with laughter
Paul Paul
Post #393948 30th Jun 2016 10:42pm
J90
France 2006 Range Rover Vogue Td6 Java Black
Peanut butter has previously been recommended on the detailing world forum as a means of bringing tired exterior plastic trim back to life.
I'm assuming one would use the cheapest smooth peanut butter you could find because of its high palm oil content? Travelling around in circles again.
Post #393961 1st Jul 2016 12:58am
Wrong topic. Embarassed
Post #393964 1st Jul 2016 7:07am
1959terry
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
Not used it myself however i heard that teak oil works well. Maybe someone can confirm? 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
2009 Triumph Bonneville, 1959 Triumph Bonneville, 1969 Triumph Bonneville, 1975 T160 Triumph Trident, 2014 Suzuki Gladius, 1990 Harley Davidson Fat Boy.
Post #393973 1st Jul 2016 9:40am
n1cktdv8
Peanut butter does work tbh on plastic trim, but it's an expensive route as a proper restorer will be the same once you use it a few times !!
I'd say remove and throw them in a local spray shop or get some rattle cans made up and DIY it. Colour code or keep as brunel but now's your chance to try Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #393978 1st Jul 2016 9:55am
Peanut, or any other oil is a temporary solution to "some" trims, the unpainted grained plastic, the ones the OP is talking about are painted so peanut butter will just make squirrels attack them!!!
Look in the WIKI for my door handle refurb, the best paint match I could find is listed and all the painted trim can be refurbished the same way... Thumbs Up
Edit.. Link here...
http://www.fullfatrr.com/forum/topic27260.html Pete
Post #393997 1st Jul 2016 12:22pm
marsie
Think i may see about colour coding or going black?
This is what i am dealing with
Paul Paul
Post #394039 1st Jul 2016 6:57pm
