![]() | Home > Technical (L322) > Detachable Tow Bar |
You will need the exhaust hangers off the new car but no quite straightforward , you will need help putting the bumper on something to support it 2008 MY Supercharged
Sportex Member Since: 12 Jun 2010 Location: Up North Posts: 366 ![]() ![]() ![]() |
will the car need a data down load of some description to let it know there is now a tow bar fitted, heard tales that it needs to know for the electrics and suspension etc.? No body told me there would be days like these
steeplejack Member Since: 11 Apr 2016 Location: Gloucestershire Posts: 19 ![]() ![]() |
Not if you have the genuine LR kit with ECU. You would need to remove the towing ecu and harness and fit it to the new car. It's going to be easy enough to find as it's connected to the towing electrics harness. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Electrics won�t work as they changed from 2009my> so, you will need a new plug in harness for the 2011 |
any advice on best source for new wiring kit for the 2011? No body told me there would be days like these
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3217 ![]() ![]() ![]() |
There's one on Ebay at the moment. cant find the link. sorry. |
Ollie_247 Member Since: 26 Nov 2015 Location: Buckinghamshire Posts: 35 ![]() ![]() ![]() |
can't fault the PF Jones wiring kits and there range of tow bars.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8742 ![]() ![]() ![]() |
Or just ask Dan how much it is.
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 ![]() ![]() ![]() |
this is the reason why I've held on to my hangers 2007 tdv8 se ,stornaway grey |
