Home > Technical (L322) > Detachable Tow Bar
Sportex
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Detachable Tow Bar
Hi guys, long time no speak. I am trading my 57 RR for (unsurprisingly) another RR 2011. Is it easy to take off the tow bar and electrics and fit to the new car, or is it more complicated than I can imagine? No body told me there would be days like these
L Reg dark purple/burgundy sort of Disco
R Reg very red disco
Bright Silver disco TD5
Sort of bright girly powder blue disco TD5
Gone (a while back) 1999 P38 4ltre Autobiography. 13 miles to the gallon, 10,000 miles to the engine
Gone MY06 RRS HSE Rimini Red
Gone MY10 RRS HSE Purple
Gone 2007 TDV8 Vogue OF Stornoway Grey (In Love again)
2011 4.4 TDV8 Vogue Baltic Blue
MY66 VOGUE TDV6 3.0 Red
Post #392888 24th Jun 2016 12:43pm
You will need the exhaust hangers off the new car but no quite straightforward , you will need help putting the bumper on something to support it 2008 MY Supercharged
Post #392896 24th Jun 2016 1:38pm
Sportex
will the car need a data down load of some description to let it know there is now a tow bar fitted, heard tales that it needs to know for the electrics and suspension etc.? No body told me there would be days like these
Post #392905 24th Jun 2016 2:59pm
steeplejack
Wales
Not if you have the genuine LR kit with ECU. You would need to remove the towing ecu and harness and fit it to the new car. It's going to be easy enough to find as it's connected to the towing electrics harness.
Post #392937 24th Jun 2016 8:53pm
Electrics won�t work as they changed from 2009my> so, you will need a new plug in harness for the 2011 Thumbs Up (no ECU on 2009> Thumbs Up
Obviously your used wiring/ECU kit will have a used resale value Thumbs Up
Post #392957 25th Jun 2016 12:12am
Sportex
any advice on best source for new wiring kit for the 2011? No body told me there would be days like these
Post #393267 27th Jun 2016 3:31pm
Dolphinboy
There's one on Ebay at the moment. cant find the link. sorry. Mr. Green
Post #393268 27th Jun 2016 3:47pm
Ollie_247
United Kingdom 2007 Range Rover Vogue SE TDV8 Orkney Grey
can't fault the PF Jones wiring kits and there range of tow bars.
I've just fitted one to my 2007 and was easy to fit, it was done in a couple of hours.
Wiring is just plug and play for me no reprograming that is branded around on the web.
I did mine laying on the driveway like I have done with all 4 tow bar's I've fitted The MOT Track days Test Dummy
2007 Vogue SE TDV8
Post #393818 30th Jun 2016 12:54pm
Or just ask Dan how much it is.
I can't remember how much mine was for the FF but its only a socket and some wires, and I'm sure it will work though there are settings in the CCF which should be changed thats not to say it won't work if they aren't.....
In terms of the metalware it should just swap straight over, but as said the towing eye and hangers will need swapping over to the old car, a few big bolts and you will be set. There is nothing that can't be fixed with a hammer😜😜
Post #393870 30th Jun 2016 4:49pm
rangie47
this is the reason why I've held on to my hangers 2007 tdv8 se ,stornaway grey
Post #393917 30th Jun 2016 8:31pm
