Home > In Car Electronics (L322) > in car phone to bluetooth - i'm getting confused? |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 351 |
At present I've got a cradle in the armrest for an unknown phone and the previous owner has had a parrot kit fitted. I'd like to ditch the parrot and just use OEM stuff if possible but I'm getting confused, I think most of the info seams to be for the older BMW stuff and I don't want to go buying the wrong thing.
14th Jun 2016 10:36am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7797 |
Is this for the td6 in your profile, or the tdv8 in your signature?
14th Jun 2016 5:03pm |
It's in a 2007 tdv8 vogue se Current
15th Jun 2016 2:50am |
I've only fitted "OEM" Bluetooth to my td6, which was BMW based, so can't help you I'm afraid. The talk on here about re-pinning and ULF's is only for the early non touchscreen.
15th Jun 2016 4:47am |
No nothing comes up on my phone, when I press the phone button on the headunit it just says phone not connected or something like that.
15th Jun 2016 6:39am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
I would suspect a dodgy BT unit - but clearly hard to diagnose remotely.
15th Jun 2016 6:50am |
So.... had a quick look in the boot again, the nokia box is there but with nothing plugged in to it. When I get chance I pull it out and check the part number.
15th Jun 2016 1:08pm |
forgot to add that there is a big multiplug that isnt plugged in but the MOST connection has a plug in it but no wires fitted to the plug?? acting as a blank. Current
16th Jun 2016 3:28pm |
