Home > In Car Electronics (L322) > in car phone to bluetooth - i'm getting confused?
andygts
At present I've got a cradle in the armrest for an unknown phone and the previous owner has had a parrot kit fitted. I'd like to ditch the parrot and just use OEM stuff if possible but I'm getting confused, I think most of the info seams to be for the older BMW stuff and I don't want to go buying the wrong thing.
Is it as simple as unplugging the current nokia box in the LH rear compartment and replacing it with a nokia bluetooth variant? Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #391591 14th Jun 2016 10:36am
mjdronfield
Is this for the td6 in your profile, or the tdv8 in your signature?
I'm guessing the tdv8 as you refer to the "older" BMW stuff...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #391646 14th Jun 2016 5:03pm
andygts
It's in a 2007 tdv8 vogue se Current
Previous
Post #391685 15th Jun 2016 2:50am
mjdronfield
I've only fitted "OEM" Bluetooth to my td6, which was BMW based, so can't help you I'm afraid. The talk on here about re-pinning and ULF's is only for the early non touchscreen.
There are a few on here who should be able to though....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #391688 15th Jun 2016 4:47am
A 2007 should come with Bluetooth - IIRC the arm rest holder was more of a charger - there should still be bluetooth.
I suspect that the BT unit packed up at come point - not sure why someone would have installed an aftermarket Parrot system otherwise..... unless it does streaming music, or something that the factory unit doesn't.
When scanning for pairing, I assume Land Rover doesn't pop up as an option ?
Post #391692 15th Jun 2016 6:10am
andygts
No nothing comes up on my phone, when I press the phone button on the headunit it just says phone not connected or something like that.
The parrot system is the basic no frills Bluetooth system. Current
Previous
Post #391694 15th Jun 2016 6:39am
I would suspect a dodgy BT unit - but clearly hard to diagnose remotely.
Wiggs is the man for all things BlueTooth Thumbs Up
http://www.bluetoothexchange.co.uk
Post #391696 15th Jun 2016 6:50am
andygts
So.... had a quick look in the boot again, the nokia box is there but with nothing plugged in to it. When I get chance I pull it out and check the part number.
The IIDtool can do the firmware update/reflash can it not?? with having a parrot fitted I'd take a guess that my nokia module has thrown its toys out of the pram so i've nothing to lose trying flash it and it looks like Wiggs wouldn't do an exchange on it. Current
Previous
Post #391756 15th Jun 2016 1:08pm
andygts
forgot to add that there is a big multiplug that isnt plugged in but the MOST connection has a plug in it but no wires fitted to the plug?? acting as a blank. Current
Previous
Post #391908 16th Jun 2016 3:28pm
