Home > Technical (L322) > Adaptive Dynamic Fault
AshC
United Kingdom 2010 Range Rover Vogue TDV8 Alaska White
Hi All,
Ive got the Adaptive dynamic fault up again and I've found the break in the wire but decided to replace with the upgraded harness. My question is, what is the adaptive dynamic fault. Guessing its to do with the suspension but just not sure exactly what it does??
Cheers
Ash
Post #391600 14th Jun 2016 11:39am
Andy B
Hi Ash,
'Adaptive dynamics continuously analyses the vehicle's movements while being driven. The system will react instantaneously to road conditions and the driver's actions. Infinitely variable suspension dampers will help to maintain a composed and balanced ride'
You'll note the ride is not so smooth when you get the Adaptive Dynamics Fault as the system isn't continuously adjusting.
Cheers,
Andy SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #391602 14th Jun 2016 12:14pm
AshC
That makes total sense.
Driving to work this morning it felt quite a bumpy/floaty ride but i thought it was all in my head.
Should feel like a new car again in a few days.
Post #391604 14th Jun 2016 12:26pm
Andy B
Yep, certainly makes a difference when it's working! Very Happy SDV8 AB MY 2019
Post #391610 14th Jun 2016 1:05pm
Mr Tee
Mine just went ping an hour ago...
Post #391655 14th Jun 2016 6:38pm
AshC
The fault is easy to find as is repair but this is the second time it's happened and wire feels very weak. Worth investing in the upgrade.
Post #391658 14th Jun 2016 6:46pm
Mr Tee
Agreed , I have the upgrade kit did the other side a few months ago, so we can say the life expectancy is 6 years Shocked
Post #391669 14th Jun 2016 8:58pm
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
6 years? So I should expect mine to go shortly, then. Rolling Eyes
What's this 'upgrade kit' consist of??? Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #391683 15th Jun 2016 2:12am
AshC
Mainly it's just a longer wire. The original wire is very tight and being that it is a thin wire over time just brakes.
I did originally solder mine back together but that has only bought me a few months. I think the upgrade is only about £30 if I remember correctly.
Post #391690 15th Jun 2016 5:47am
Mr Tee
I'll take a photo later & post
Post #391693 15th Jun 2016 6:31am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
When I got that earlier this year it was a rear shocker that had failed, replaced under extended warranty.
Ian
Post #391704 15th Jun 2016 7:46am
Mr Tee
Most folk say "character", in reality it's utterly shyte build quality!
Post #391736 15th Jun 2016 10:15am
AshC
Your right, the suspension wire is a pure sign of bad engineering or design. The fact it fails so commonly should have made it a recall.
Post #391742 15th Jun 2016 10:42am
Spooky
Yeah - photos would be great ... along with a part number?? Regards,
Mick
Post #391962 17th Jun 2016 4:40am
Mr Tee
Part number is on a thread in here somewhere , along with a photo: http://www.fullfatrr.com/forum/topic22949....e+dynamics
Post #391972 17th Jun 2016 6:53am
