Home > Technical (L322) > L322 gearbox kick down problem
Mouse
France 2004 Range Rover Vogue Td6 Nara Bronze
Hi All, new to this site, some very good information posted by knowledgable people, thank you in advance.
My problem is :- l322 td6, 2004.
Had a recon box fitted, have not done many miles, (20-25k ) going up through the gears is ok, changes up fine.
When cruising in top gear kick down goes out of gear but not into gear, it remains in neutral and the revs go up, drop the revs and it engages gear with a clonk.
Any help much appreciated.
Post #391643 14th Jun 2016 5:32pm
Try lubricating the gear linkage under the car , they get gummed up and stop engaging properly . 2008 MY Supercharged
Post #391682 15th Jun 2016 1:52am
Mouse
Thank you, I will look,
I just think it is possibly the valve assembly, but not sure if that would cause this problem.
Post #391963 17th Jun 2016 6:09am
