Home > Maintenance & Mods (L322) > Strange wind noise at speed
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Driving back from Devon at the weekend at a reasonable motorway speed Embarassed I occasionally got a sound like a Horn being blown for a second or so. Thought it might be one of the air intake flaps resonating etc. Only hear it at high speed and never had it before.
Anyone else had a similar thing. "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #391103 10th Jun 2016 7:00pm
mr_spock
Yes, like someone blowing across the top of a large bottle! I think it's the screen base trim or pillar trim from what I've read. Worse in cross winds.
Post #391104 10th Jun 2016 7:04pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Happens on my car, but only on warm days (over 20 deg cels) and after a period of motorway driving at at 70+. If itvwas the screen/pillar trim, it would happen all the time wouldn't it?
Post #391111 10th Jun 2016 7:28pm
mr_spock
No personal experience, but also read it can be the rubber seal between the cabin air intake and the bonnet, which may need cleaning and a little Vaseline on. Also it may go away if the recirculating air flap is opened (ie turn off recirc)
Post #391129 10th Jun 2016 8:15pm
cliff5.0sc
I've heard this is caused by (at least) one of two things. the recirculation motor faulty or not closing opening properly/completely or ususally the lower (sometimes upper) windshield molding bending and coming apart from windshield. OffRoadRover.com An American Western Range Rover Off Road Blog
Post #391131 10th Jun 2016 8:22pm
MrP
Thanks for the replies - I will check the places suggested. I did switch off the recirc as I thought of that first but it didn't make any difference. It was over 20 degrees that day and not had it since. "On first name terms with my local Dealer......now."
Post #391287 11th Jun 2016 6:48pm
sako243
My vote would be the a pillar trim, depends quite a bit on if there are cross winds etc. Ed
Post #391307 11th Jun 2016 8:54pm
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
I've had/have similar wind noises. One was the A pillar trim. Cracked part broke off so that sound is gone. The other may be similar to yours. I notice there is a vibration in the windshield when it gets tone. Between 62 and 72 MPH.
Post #391328 12th Jun 2016 2:04am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Happens regularly. On a motorway run. After about 20 minutes.
DPF activating....
Post #391395 12th Jun 2016 2:39pm
mr_spock
I cleaned and treated my faded screen base trim and the sealing rubbers under the bonnet with Meguiar's plastic treatment. Can't remember the exact name. It got the scuttle trim to the right colour after a couple of goes and cleaned the sealing rubbers. Went on a 70+ run today with no noise at all.
Not a scientific test, and there was no crosswind, but I would normally hear some noise.
Post #391400 12th Jun 2016 3:58pm
doclees
DPF activating....
I'm not sure what reply you are commenting on. If it's mine my sound returns anytime I'm in that speed range.
Post #391518 13th Jun 2016 4:08pm
had similar, was the sunroof seal, but if your noise isn't coming from... up... then its probably not that.
a quick clean round it sorted the noise. There is nothing that can't be fixed with a hammer😜😜
Post #391526 13th Jun 2016 5:36pm
CharlieBaja
United Kingdom 2007 Range Rover Autobiography TDV8 Buckingham Blue
I get a noise at about 70+ as you say and it sounds like a ticket or something is caught in a wind socket flapping around and sadly louder than the speakers sometimes. It comes from the LHS of the screen so sadly cant see it when i drive. Not sure what it is!!
Post #391549 13th Jun 2016 9:41pm
mr_spock
I think we have different noises here! To summarise my experiences:
Noise: Mid-pitch whistle from lower screen area, like blowing over the top of a big bottle. Not affected by position of air recirculation flap
Solution: Clean and treat rubber edge trim in engine compartment where it meets the bonnet. Push scuttle panel fixing pins fully home.
Other possible causes (from t'internet): Poorly fitting A-pillar trim, poorly fitting scuttle panel trim
Noise: Kind of farty wind noise from left side front
Solution: Mudguard on front LHS side step not well fitted. Loosening and pushing back towards the body reduced the wind noise.
Noise: Wind noise from rear LHS
Solution: Door rubber seal missing! Replaced
Noise: Occasional wind noise from rear RHS
Solution: Window switch contacts needed cleaning, as the window kept opening Smile
Post #391575 14th Jun 2016 7:52am
finprog
Australia 2012 Range Rover Autobiography TDV8 Java Black
I have similar noise coming from LH side while driving over 70km/h. Could it be left a lose wing grille air intake?
Post #392441 20th Jun 2016 11:45pm
