Home > Maintenance & Mods (L322) > Strange wind noise at speed |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 |
Driving back from Devon at the weekend at a reasonable motorway speed I occasionally got a sound like a Horn being blown for a second or so. Thought it might be one of the air intake flaps resonating etc. Only hear it at high speed and never had it before.
10th Jun 2016 7:00pm |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1031 |
Happens on my car, but only on warm days (over 20 deg cels) and after a period of motorway driving at at 70+. If itvwas the screen/pillar trim, it would happen all the time wouldn't it? |
10th Jun 2016 7:28pm |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
No personal experience, but also read it can be the rubber seal between the cabin air intake and the bonnet, which may need cleaning and a little Vaseline on. Also it may go away if the recirculating air flap is opened (ie turn off recirc) |
10th Jun 2016 8:15pm |
cliff5.0sc Member Since: 29 Dec 2015 Location: USA Posts: 137 |
I've heard this is caused by (at least) one of two things. the recirculation motor faulty or not closing opening properly/completely or ususally the lower (sometimes upper) windshield molding bending and coming apart from windshield. OffRoadRover.com An American Western Range Rover Off Road Blog |
10th Jun 2016 8:22pm |
Thanks for the replies - I will check the places suggested. I did switch off the recirc as I thought of that first but it didn't make any difference. It was over 20 degrees that day and not had it since. "On first name terms with my local Dealer......now."
11th Jun 2016 6:48pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 610 |
My vote would be the a pillar trim, depends quite a bit on if there are cross winds etc. Ed |
11th Jun 2016 8:54pm |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 |
I've had/have similar wind noises. One was the A pillar trim. Cracked part broke off so that sound is gone. The other may be similar to yours. I notice there is a vibration in the windshield when it gets tone. Between 62 and 72 MPH. |
12th Jun 2016 2:04am |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 809 |
Happens regularly. On a motorway run. After about 20 minutes.
12th Jun 2016 2:39pm |
I cleaned and treated my faded screen base trim and the sealing rubbers under the bonnet with Meguiar's plastic treatment. Can't remember the exact name. It got the scuttle trim to the right colour after a couple of goes and cleaned the sealing rubbers. Went on a 70+ run today with no noise at all.
12th Jun 2016 3:58pm |
I'm not sure what reply you are commenting on. If it's mine my sound returns anytime I'm in that speed range. |
13th Jun 2016 4:08pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8636 |
had similar, was the sunroof seal, but if your noise isn't coming from... up... then its probably not that.
13th Jun 2016 5:36pm |
CharlieBaja Member Since: 01 Feb 2016 Location: Surrey Posts: 52 |
I get a noise at about 70+ as you say and it sounds like a ticket or something is caught in a wind socket flapping around and sadly louder than the speakers sometimes. It comes from the LHS of the screen so sadly cant see it when i drive. Not sure what it is!! |
13th Jun 2016 9:41pm |
I think we have different noises here! To summarise my experiences:
14th Jun 2016 7:52am |
finprog Member Since: 20 Jun 2016 Location: Sydney Posts: 3 |
I have similar noise coming from LH side while driving over 70km/h. Could it be left a lose wing grille air intake? |
20th Jun 2016 11:45pm |
