Home > Technical (L322) > Steering Wheel tilt Mechanism |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
its broken.......theres a lot about this, have a search ... - .- -.
8th Jun 2016 5:10am |
SHasson1690 Member Since: 26 May 2016 Location: Glasgow Posts: 20 |
Thanks |
8th Jun 2016 6:17am |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Expensive replacement plastic part from a chap in Germany fixed it for me, far cheaper than replacing the complete mechanism and a home job to boot. |
8th Jun 2016 4:10pm |
1959terry Member Since: 28 Apr 2014 Location: London Posts: 128 |
This Is the part i believe
8th Jun 2016 7:37pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 791 |
The poster is asking about Tilt , not reach so that part is not involved. The Tilt has a weak point where the a piece of metal snaps off which in the worst case leaves the steering wheel in your lap. Question is has it ever worked in your ownership? if so it could be seized, motor stuffed, turned off etc. If it has never worked it could be the previous owner has done a modification after the tilt metal part has broken off. Easy enough to take off the steering column cover to see whats going on.
9th Jun 2016 2:36am |
Sorry for the misunderstanding, neither the reach or tilt mechanism work, this was like this when I bought the car.
9th Jun 2016 5:49pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
If you remove the steering column shroud (three T20 torx screws, you need a screwdriver not a socket to reach them) then you can manually adjust it with either an allen key in the end of the gear screw or a flatblade screwdriver depending on which type you have...
9th Jun 2016 6:20pm |
Mr bump Member Since: 30 May 2016 Location: Bucks Posts: 6 |
Did you resolve your problem as mine is exactly the same . The stalk does nothing at all |
13th Jul 2016 6:19pm |
It's a well known failure, if it's not physically broken then the motors give up, they are a fortune to buy, several places around doing reconditioned units but they are still expensive.... Pete
13th Jul 2016 6:29pm |
Oh ok , not quite the same as mine then. My colum works as adjusts to previous owners settings when you press the memory buttons but the stalk does nothing. Hoping it may just be a stalk fault, need to get a replacement and fingers crossed. |
13th Jul 2016 6:32pm |
Oh I see... OP's didn't work at all so not quite the same, you're in luck, will probably be the stalk which is much cheaper than the motors... result... Pete
13th Jul 2016 6:37pm |
