![]() | Home > Technical (L322) > EAS 23.48 bar |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Something has gone wrong there it shouldn't be higher that around 190 PSI yours is at 340 PSI....
Beemergriff Member Since: 06 May 2016 Location: Northamptonshire Posts: 62 ![]() ![]() |
Thanks Pete
Just poked small cable tie into connector holes at both ends of air-tank. Conclusion, there isn't a non-return valve so sensor is defective and needs replacing. That's about £35 and hopefully I can get one be tomorrow and put it all back together.
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
The compressor could not possibly generate 23 bar - nowhere near it!
Hi Wealy
Sounds like the culprit....
So . . Pressure sensor replaced, and valve block too. All put back together but even after reset, still no Air Suspension.
If you get the codes read, or work through the live values you won't be spending good money on guesswork...!!! Pete
Thanks for the suggestion.
Oh yes, very easy to check the continuity of the wires, I bet they are fine though and the fault lies elsewhere, you have already spent money on a sensor which was probably OK, it is easy to get into just replacing bits you "think" are broken...
