![]() | Home > Maintenance & Mods (L322) > Howto: FFRR TD6 '02 Replace Front and Rear Brake Lines |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
The advantage for me is having the ends pre-flared with the fittings also added. Plus the front to rears are only £15. The flexis in the other hand are £82 each!
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
The guy in the video is talking OOHA about the rear pipes route. He probably means tank cover as I previously said.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8514 ![]() ![]() ![]() |
Britpart do rear flexis for £15 each, they are good quality and fit perfectly.. they also have no moving parts and that's my reasoning for going non genuine...
Well I tackled mine today. I bought the front to rear pipes from Land Rover (£26 for the two) and 2x britpart flexis from Island 4x4 at £18 each
I might have. I was given a spare one which is in the loft still in the bag. Give me a couple of days to get up there and dig it out. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1291 ![]() ![]() ![]() |
Thanks mate. I'm in Telford so I could come and collect it if you wanted to sell it. |
I only have the one so you’d have to buy the other one. I’ll get it out and we can sort something out. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Would be nice if it was for the right rear. |
Any luck Andy? |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 173 ![]() ![]() ![]() |
Does anyone have the part nos of the front to rear brake pipes.
Both the pipes, for the rear left brake for the rear right brake, run down the left hand side of the car. There are no brake pipe runs on the right hand side . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Thanks Joe, got it now. |
quick question : Can steel pipes be joined with copper ones ? will it work or any ill effects ? |
As long as the flares and connectors match up.
