Home > Maintenance & Mods (L322) > heavy steering
STU TDV8
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
heavy steering
What would cause heavy steering on a TDV8 was ok then was heavy? ..
Post #388428 24th May 2016 8:03am
sleepezy
In my case - loss of PAS fluid - simple to see in the engine bay (can't remember where but it's in the book, think it's the pink reservoir but check).
Topped it up and was all OK until garage tightened a loose pipe.
Post #388430 24th May 2016 8:12am
Servotronic transducer valve or Body Processor Module , if you get the codes read it will probably show short circuited on servotronic valve and open circuit . 2008 MY Supercharged
Post #388454 24th May 2016 11:13am
STU TDV8
Ok ill check where is the valve exactly? .
Post #388500 24th May 2016 4:39pm
Offside wheel arch tucked in tight above the steering arm , bolts usually corroded and will shear when you try to remove them so it will be out with the Dremel to cut them . The main problem is there is no clear way to tell if it is the valve or ECU so you change the valve first and if that doesn't do it you change the Body Processor Module and that has to be a new one and programed to the vehicle but this is possible with an iiD Tool. 2008 MY Supercharged
Post #388550 25th May 2016 12:38am
STU TDV8
Ok thank's for your help Wink
Post #388556 25th May 2016 6:55am
STU TDV8
Tried the vavle and it made no difference ? , Where do i source a "body processor module" ??..
Is that the next thing to try ? .
Post #389560 31st May 2016 6:57pm
Duckworth Dan is you man ( site sponsor here) It's a very simple job , just unbolt the passenger seat and under the plastic flap on the floor is the BPM . Do you have a diagnostic tool to copy and swap the setting from the old unit to the new unit ?
I'm guessing no because you haven't come back with any fault codes so you may need to seek out an independent mechanic with Land Rover testbook . 2008 MY Supercharged
Post #389614 1st Jun 2016 1:12am
STU TDV8
Can you buy them second hand ?..Or do they have to be new ?.
Post #389643 1st Jun 2016 9:30am
Have you had the codes read...???
You could be spending a lot of money for no reason if it was something else, there are numerous other things it could be, Axle has highlighted the most common and suggested reading the codes to confirm but they are certainly not the only reasons for your fault... Pete
Post #389660 1st Jun 2016 9:58am
STU TDV8
Ill read the code's tonight i have access to a sollus diagnostic reader..
Post #389701 1st Jun 2016 3:34pm
STU TDV8
Just had the Body possessor module read came back with "servo valve or connection's short circuit , servo vavle or connection's open circuit" ??....
I have replaced the transducer on the rack what is the servo valve ? ..
Post #390290 5th Jun 2016 4:51pm
The transducer is the servo valve, if that's OK then it is probably the BECM, pretty sure I remember someone had a problem with it's earthing bolt which is at the bottom of the "B" pillar on the passenger side, you have to remove the seat and carpet to get at it I think... They had a bad earth that stopped the power steering working, others have had faulty BECM's...
Do a search there are loads of threads on the problem... Thumbs Up Thumbs Up Pete
Post #390298 5th Jun 2016 5:51pm
