Home > Maintenance & Mods (L322) > heavy steering |
STU TDV8 Member Since: 03 Apr 2016 Location: norfolk Posts: 65 |
What would cause heavy steering on a TDV8 was ok then was heavy? .. |
24th May 2016 8:03am |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 |
In my case - loss of PAS fluid - simple to see in the engine bay (can't remember where but it's in the book, think it's the pink reservoir but check).
24th May 2016 8:12am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Servotronic transducer valve or Body Processor Module , if you get the codes read it will probably show short circuited on servotronic valve and open circuit . 2008 MY Supercharged
24th May 2016 11:13am |
Ok ill check where is the valve exactly? . |
24th May 2016 4:39pm |
Offside wheel arch tucked in tight above the steering arm , bolts usually corroded and will shear when you try to remove them so it will be out with the Dremel to cut them . The main problem is there is no clear way to tell if it is the valve or ECU so you change the valve first and if that doesn't do it you change the Body Processor Module and that has to be a new one and programed to the vehicle but this is possible with an iiD Tool. 2008 MY Supercharged
25th May 2016 12:38am |
Ok thank's for your help |
25th May 2016 6:55am |
Duckworth Dan is you man ( site sponsor here) It's a very simple job , just unbolt the passenger seat and under the plastic flap on the floor is the BPM . Do you have a diagnostic tool to copy and swap the setting from the old unit to the new unit ?
1st Jun 2016 1:12am |
Can you buy them second hand ?..Or do they have to be new ?. |
1st Jun 2016 9:30am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Have you had the codes read...???
1st Jun 2016 9:58am |
Ill read the code's tonight i have access to a sollus diagnostic reader.. |
1st Jun 2016 3:34pm |
Just had the Body possessor module read came back with "servo valve or connection's short circuit , servo vavle or connection's open circuit" ??....
5th Jun 2016 4:51pm |
The transducer is the servo valve, if that's OK then it is probably the BECM, pretty sure I remember someone had a problem with it's earthing bolt which is at the bottom of the "B" pillar on the passenger side, you have to remove the seat and carpet to get at it I think... They had a bad earth that stopped the power steering working, others have had faulty BECM's...
5th Jun 2016 5:51pm |
