Home > Technical (L322) > Few questions as a new owner! TD6 HSE |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
Hi all,
19th May 2016 11:03pm |
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 |
Maybe change the torque converter if it's high mileage and hasn't been done. On the TD6 they go without warning and take the box along with them.
20th May 2016 4:13am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Pleased to hear you have your own code reader now
20th May 2016 7:26am |
Thanks for the info guys, much appreciated!
20th May 2016 8:26am |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Hi stacker, when your cruising at say 60mph, is the rev counter reading about 2,000 rpm, if it is then your in tc lockup, any higher say 2500 -3000rpm, the tc is not locked up. As an observation mine doesn't particularly roar, but is chipped, which I believe makes the gear changes better.
20th May 2016 8:49am |
Thanks again for the replies.
20th May 2016 11:08am |
Good news if there are no fault codes logged.
20th May 2016 6:43pm |
I'll keep my eye on it!
20th May 2016 10:38pm |
Yes that's correct. |
21st May 2016 4:26am |
