![]() | Home > Technical (L322) > Few questions as a new owner! TD6 HSE |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
Hi all,
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 ![]() ![]() |
Maybe change the torque converter if it's high mileage and hasn't been done. On the TD6 they go without warning and take the box along with them.
Pleased to hear you have your own code reader now |
Thanks for the info guys, much appreciated!
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Hi stacker, when your cruising at say 60mph, is the rev counter reading about 2,000 rpm, if it is then your in tc lockup, any higher say 2500 -3000rpm, the tc is not locked up. As an observation mine doesn't particularly roar, but is chipped, which I believe makes the gear changes better.
Thanks again for the replies.
Good news if there are no fault codes logged.
I'll keep my eye on it!
Yes that's correct. |
