Home > Technical (L322) > Few questions as a new owner! TD6 HSE
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Hi all,
Put my L322 TD6 in for MOT, and to my surprise she passed first time! Very happy, but coming up from a 4.6 V8 P38 its all a bit new and I'm a bit apprehensive about it all Sad
Few little niggles I'd welcome any advice / links / comments:
- when sitting at a constant speed, if I want to accelerate even the tiniest bit the engine literally roars, only above say 40 but almost like kickdown, but not quite as powerful... Is this normal for these cars?
- drivers side mirror doesn't stay in on power fold, but there is also a bit of movement on it when it's out, I'm guessing some bit of plastic inside is worn / snapped?
- squeak / rattle when turning the wheel, coming from the front suspension I believe, there are a few knocks from the front suspension which were not picked up on MOT, but haven't had a chance to check myself yet!
- finally, the rear parking sensors, one moment they work, next my code reader says left, then centre left, I'm guessing it will be a problem with the loom judging by previous threads as one moment it clicks, the next time it won't (different sensors)!
Sorry for all the questions, I'm new to the car and paranoid something is going to go wrong with the gearbox, will change the fluid soon and give the car a service, but did 70 miles today and everything seemed ok except above... And the rear brows squeak when slowing down (some clown forgot to grease the callers Wink)
Thanks in advance, any input appreciated Smile
Post #387949 19th May 2016 11:03pm
chex
Kenya
Maybe change the torque converter if it's high mileage and hasn't been done. On the TD6 they go without warning and take the box along with them.
£200 rebuilt from JPAT I think www.jpat.co.uk 2004 L322 V8
Post #387952 20th May 2016 4:13am
Pleased to hear you have your own code reader now Wink
Roaring engine:
TD6 can be a bit noisy on acceleration, but could be the TC or the viscous fan (you could simply remove the fan and see if things improve without it, a TD6 will run quite happily without a VF.
Squeak & Rattle
Could be steering rack, could be brake mudshields rattling, could be ARB links, could be suspension bushes, all covered on here somewhere
Mirror
Sounds like the motor has gone , a good howto on here for a DIY repair. Also try the double tap on the fold button trick, this sometimes resolves mirror issues
Parking sensors
Your guess sounds like the right direction, if it is intermittent and keeps swapping around, loom or ECU are the likely culprits
Gearbox
Yes, change the transmission fluid and filter as soon as you can, then change it again after a couple of weeks. You will not get it all out first time around. Check for metal in the fluid, if it looks like metallic paint then there could be worse to come. The gearboxes are a bit flakey, but with regular servicing and fluid change, they do seem to hold up?
If you haven't found the WIKI yet, look for the link in the banner at the top of the forum .
Post #387975 20th May 2016 7:26am
Stacker
Thanks for the info guys, much appreciated!
Regarding the torque converter, the car is on 140,000miles so without a receipt I wouldn't know, but would guess if it was going to, it probably would have been changed?
I'll review your information tonight Joe, thanks mate Smile
Post #387984 20th May 2016 8:26am
chex
Kenya
Not sure if it's supposed to be changed as a service item at specific mileage. On the TD6 they give no warning when they go, on the 4.4 they start vibrating and slipping but the TD6 box is damped so you don't feel it until its gone. 2004 L322 V8
Post #387986 20th May 2016 8:32am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Hi stacker, when your cruising at say 60mph, is the rev counter reading about 2,000 rpm, if it is then your in tc lockup, any higher say 2500 -3000rpm, the tc is not locked up. As an observation mine doesn't particularly roar, but is chipped, which I believe makes the gear changes better.
another clue is fuel consumption , what's the screen saying, I know these can be a bit out.
all rr problems mate. Stick with it and enjoy. Thumbs Up
Post #387988 20th May 2016 8:49am
Stacker
Thanks again for the replies.
One thing ticked off the list now, is the mirror. It was moving by probably half an inch everytime I accelerated or brakes, I had a look on the wiki, and discovered that I pop the cap off the bottom, and the four torx screws weren't tight. Tightened them up and all is good now, I love an easy fix.
Greg: I'm not sure actually, I haven't taken much notice but next time I use the car I will check and report back. I'm pretty sure when i'm just cruising along the revs are quite low, it's only when I accelerate the smallest bit they fire up!!
Fuel consumption - It's reading about 19mpg at the moment, but as some clown has fitted an aftermarket stereo, I haven't been able to reset this I believe, so that is since changing the battery and the car has been doing quite a bit of idling, when doing diagnostics and for the MOT. The gearbox doesn't appear to have any fault codes which I'm hoping is a good start.
Regard to the chip, buying a second hand vehicle I will never know if it's been chipped or not, but I guess that could be a possibility if it's not normal td6 behaviour, I will have a look around and see if anything looks suspicious!
Post #388006 20th May 2016 11:08am
gregdav
Good news if there are no fault codes logged.
Well done fixing the mirror.
Forgot you had hse, but 19 mpg seems a little low, mine reads 28 to 30 if not more in the summer.
Has it been de egr'd.? If not you will find a huge difference in performance and mpg.
good luck. Greg. Thumbs Up
Post #388066 20th May 2016 6:43pm
Stacker
I'll keep my eye on it!
My car sits at 2000rpm cruising at 60, is that good? Smile
Post #388103 20th May 2016 10:38pm
gregdav
Yes that's correct. Thumbs Up
Post #388115 21st May 2016 4:26am
