Home > In Car Electronics (L322) > Okay I admit defeat, how the hell do I add a DAB station? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
theres a download link to the owners manual in the wiki, but this might help,
16th May 2016 11:36am |
nemesisdazza Member Since: 20 May 2015 Location: South East Posts: 76 |
Cheers Stan I had tried that the two stations that I mention just don't appear anywhere but show straight away when I search say in my missus's gof? |
16th May 2016 12:03pm |
Mine's much the same, couldn't find it's own ar5e in the dark if it used both hands. I didn't find any way to search using text so just went back to FM.
16th May 2016 12:46pm |
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 167 |
appears I am not alone then...DAB in mine is next to useless at finding stations I actually want to listen to
17th May 2016 1:18pm |
Berty Member Since: 04 Jan 2016 Location: Leeds Posts: 73 |
I do the search in mine and still can't get the ones I want, there showing up but when you try them it says no reception, absolute 70,s and 80,s for example, I get in other cars with dab in the same area and get them no problems |
17th May 2016 6:17pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Checked mine tonight and NO i cannot get absolute 80’s either any longer |
18th May 2016 12:11am |
Have you done a auto retune (I have) I know they moved frequency in April but I couldn't even get it before then in my Rangerover, Can get absolute radio, when I do the auto search I usually get all the same channels showing back up even though quite a few of them will not play just says no reception in the top bar on the screen :unsure: |
18th May 2016 12:56am |
Yep, same here |
18th May 2016 11:01am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2643 |
Had the exact same bother yesterday, eventually found it though, I'll go have a look and get back. It depends on your dab selection on the sub menu regards local/ national etc. |
18th May 2016 11:35am |
just played with mine and i have absolute 80's on mine and here's how i got it,
19th May 2016 9:03am |
Tried that today and no joy Infact I've tried every one on the enabled lists, it still shows up on the screen and says no reception, however if I go into channel list and select it from there it works, my sub channel box is unhighlighted, any one any ideas so I can get it to work on the dab 1 box tag? Is adding it as a sub channel possible ? If so how thanks Berty |
20th May 2016 6:11pm |
I didn't have the SDL NAT in my ensemble list, autotune added it and loads of others so now I have loads more stations.
24th May 2016 11:03am |
24th May 2016 11:24am |
