Home > In Car Electronics (L322) > Okay I admit defeat, how the hell do I add a DAB station?
nemesisdazza
England 2012 Range Rover Autobiography 5.0 SC V8 Santorini Black
So Kisstory has stopped working, I think they have changed frequencies, but it wont appear when I try to search for it anywhere, Wife's golf find it in seconds and its stored now but I cant for the life of me find how to add it/search for it?
Aside from the questionable choice in stations can anyone help me out?
Thanks
Darren
PS the same has happened to Absolute 80's again okay in the gold but not on Range Rover (Absolute 70's, 90's and 00 all work fine)
Post #387314 16th May 2016 12:31pm
theres a download link to the owners manual in the wiki, but this might help,
Post #387315 16th May 2016 12:36pm
nemesisdazza
Cheers Stan I had tried that the two stations that I mention just don't appear anywhere but show straight away when I search say in my missus's gof?
Post #387317 16th May 2016 1:03pm
mzplcg
Mine's much the same, couldn't find it's own ar5e in the dark if it used both hands. I didn't find any way to search using text so just went back to FM.
Not sure if it's related but I found DAB had much less range for reception and I did wonder if FM and DAB are on separate aerials. If they are the DAB one might be goosed, or possibly the amplifier block thingy for it. FM sounds fine and reception range is fine too.
Post #387321 16th May 2016 1:46pm
L19 MUD
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
appears I am not alone then...DAB in mine is next to useless at finding stations I actually want to listen to
FM working nicely
Hope they don't make the move to DAB in the near future!
Post #387506 17th May 2016 2:18pm
Berty
England 2012 Range Rover Westminster 4.4 V8 Baltic Blue
I do the search in mine and still can't get the ones I want, there showing up but when you try them it says no reception, absolute 70,s and 80,s for example, I get in other cars with dab in the same area and get them no problems Sad
Post #387568 17th May 2016 7:17pm
Checked mine tonight and NO i cannot get absolute 80’s either any longer Evil or Very Mad Evil or Very Mad Evil or Very Mad
Post #387623 18th May 2016 1:11am
Berty
Have you done a auto retune (I have) I know they moved frequency in April but I couldn't even get it before then in my Rangerover, Can get absolute radio, when I do the auto search I usually get all the same channels showing back up even though quite a few of them will not play just says no reception in the top bar on the screen :unsure:
Post #387627 18th May 2016 1:56am
Yep, same here Rolling Eyes
Post #387660 18th May 2016 12:01pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Had the exact same bother yesterday, eventually found it though, I'll go have a look and get back. It depends on your dab selection on the sub menu regards local/ national etc.
Post #387669 18th May 2016 12:35pm
just played with mine and i have absolute 80's on mine and here's how i got it,
select ensemble list
sdl nat
then autotune
you should have abs80's on the list.. ... - .- -.
Post #387805 19th May 2016 10:03am
Berty
Tried that today and no joy Infact I've tried every one on the enabled lists, it still shows up on the screen and says no reception, however if I go into channel list and select it from there it works, my sub channel box is unhighlighted, any one any ideas so I can get it to work on the dab 1 box tag? Is adding it as a sub channel possible ? If so how thanks Berty
Post #388065 20th May 2016 7:11pm
nemesisdazza
YES all sorted!
I didn't have the SDL NAT in my ensemble list, autotune added it and loads of others so now I have loads more stations.
Was a little reluctant to press autotune as wasn't sure it wouldn't overwrite all my saved stations and positions, but it didn't!
Thanks all. Very Happy Very Happy Very Happy
Darren
Post #388452 24th May 2016 12:03pm
Thumbs Up ... - .- -.
Post #388455 24th May 2016 12:24pm
