Home > Maintenance & Mods (L322) > Battery life |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35263 |
you should never do that..the FF's battery isnt up to the job and you must have the engine running if you watch a dvd or tv.. ... - .- -.
16th May 2016 10:53am |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 |
Copy that.
16th May 2016 11:15am |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Your system should shut down automatically???? |
16th May 2016 12:52pm |
Yeah, I thought the same thing.
16th May 2016 12:56pm |
You can get some more life out of it by adding a 2nd battery in the boot. I did this on an 07 VSE and it would still start after a couple of hours. You can get a Gel battery for the front of 105ah and a similar one for the back of 60ah. Both will deep cycle and still give a start at 70% discharge.
16th May 2016 1:02pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
RSE does NOT shut down like the front screen when the battery gets low
16th May 2016 2:15pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
The RR is barely able to power the clock without draining the battery over a few days, I am tempted to add a second battery in the boot. Tom
16th May 2016 3:36pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
Mine has the second battery in the boot (courtesy of dan_1984_uk) and have never had a prob. Original LR battery too! Now over 7 yrs old!
16th May 2016 5:22pm |
MrKev Member Since: 09 Aug 2015 Location: UK Posts: 22 |
Unnecessary quote removed
16th May 2016 6:13pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7792 |
I've just spent £200 on a decent cool box that heats and shuts down if battery gets low - I thought might be handy if I buy milk at dinner at work as I can't be bothered to call at the shop on the way home....
As Dolphonboy pointed out, the 2nd battery gives another 60 or so amp hours. My Engel was left on pretty much all the time and never caused a problem. Mind you, if yours has a Peltier unit it will draw a lot more current than a compressor fridge does as the compressor turns off once it's down to temperature. |
16th May 2016 6:28pm |
