Home > Maintenance & Mods (L322) > Tdv8 coolant reservoir level
Page 2 of 4 <1234>
Hammer
Australia 2007 Range Rover Vogue TDV8 Zambezi Silver
How it should look cold.
Post #385482 6th May 2016 12:42am
rar110
Ok. That settles it thanks Paul. ______________________________
Post #385721 7th May 2016 10:40am
rar110
I'm away for a couple of weeks so I can't check. Any further tips. How many hours to do the O-ring and water pump?
Thanks
Pete ______________________________
Post #386189 10th May 2016 11:09am
Hammer
First time around give your self 6 hours. Pete it's a xxxx in the butt to have to do it, but I'm glad I did mine, as while doing it I also cleaned out the intake, checked the egrs, and replaced a few seals, (throttle body,butterfly valve, egr pipe gasket) and to me it looked like they had been leaking. I've never seen smoke again since no matter how hard I boot It.
If I bought another one it would be the first thing I'd do.
It seems a bit daunting but take your time it's fairly straight forward and the housing is quite cheap.
Post #386214 10th May 2016 3:29pm
rar110
Thanks again Paul.
The service history indicates a coolant leak was repaired in March 2013 by replacing the thermostat housing. The leak continued so two months later pulled it out again to replace the "thermostat housing and oil filter housing rings". Assuming that's correct I shouldn't need another housing yet. Tell me if Im kidding myself.
Ive only noticed this lately. Im wondering if the leak is connected to the alternator being replaced in Nov 2015, which involves removing the coolant tank.
I will know more when I get back and can have a look. ______________________________
Post #386257 10th May 2016 8:37pm
sako243
Pete have you actually tried bleeding the system? I suspect you still have a leak but there's a little plastic dial on the top of the expansion tank which you open up, run the engine and it self bleeds. A search or the WSM should reveal the correct procedure. Ed
Post #386285 10th May 2016 11:41pm
rar110
Thanks I'll give it a try when I get back. ______________________________
Post #386290 11th May 2016 1:41am
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Is there any other 'jobs' or checks worth doing whilst doing the thermostat housing repair?
Post #386297 11th May 2016 8:09am
sako243
Have you done the EGRs? You'll have gained access to them by then. Ed
Post #386303 11th May 2016 8:48am
Hammer
When you say coolant tank, are you referring to over flow tank. if that was leaking I'd expect you to see coolant onthe ground. Apparently the egr coolers can also leak, they are bolted to the end on the egrs.
Sounds like you are not seeing the leak onthe ground so it's either evaporating or leaking internally.
It's very difficult to see but with some probing around the thermostat housing can be isolated to be the cause.
I will see if I can find some pics to suggest where to look.
If it is an egr cooler leaking that's a easy replacement but I don't know cost. I have heard though if the egrs have been decommissioned you can by pass the egr coolers and problem is solved.
Post #386327 11th May 2016 10:21am
rar110
thanks again Paul.
I won't be home until next week to look. I haven't noticed any coolant on the ground.
By coolant tank I mean the plastic tank in our pic. The mechanic removed the tank to fit the new alternator at the end of last year.
Coolant does swirl around in the tank when the motor's warm indicating its still in the motor.
If its an EGR cooler Ill go the emulator route and bypass the cooler. ______________________________
Post #386343 11th May 2016 11:23am
cheezels
Are the egr valves themselves, cooled?
Post #386347 11th May 2016 12:10pm
rar110
The cooler is for the exhaust gases afaik. ______________________________
Post #386355 11th May 2016 1:12pm
Hammer
Egr valve blue, egr cooler red.
Post #386554 11th May 2016 10:36pm
cheezels
So the egr valve itself doesn't have cooling water connections.
(Sorry, can't quite see)
Post #386619 12th May 2016 11:50am
Page 2 of 4 <1234>
