![]() | Home > Maintenance & Mods (L322) > Tdv8 coolant reservoir level |
Hammer Member Since: 14 Oct 2012 Location: Perth Posts: 123 ![]() ![]() ![]() |
How it should look cold.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Ok. That settles it thanks Paul. ______________________________
First time around give your self 6 hours. Pete it's a xxxx in the butt to have to do it, but I'm glad I did mine, as while doing it I also cleaned out the intake, checked the egrs, and replaced a few seals, (throttle body,butterfly valve, egr pipe gasket) and to me it looked like they had been leaking. I've never seen smoke again since no matter how hard I boot It.
Thanks again Paul.
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Pete have you actually tried bleeding the system? I suspect you still have a leak but there's a little plastic dial on the top of the expansion tank which you open up, run the engine and it self bleeds. A search or the WSM should reveal the correct procedure. Ed |
Thanks I'll give it a try when I get back. ______________________________
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
Is there any other 'jobs' or checks worth doing whilst doing the thermostat housing repair? |
Have you done the EGRs? You'll have gained access to them by then. Ed |
When you say coolant tank, are you referring to over flow tank. if that was leaking I'd expect you to see coolant onthe ground. Apparently the egr coolers can also leak, they are bolted to the end on the egrs.
thanks again Paul.
Are the egr valves themselves, cooled? |
The cooler is for the exhaust gases afaik. ______________________________
Egr valve blue, egr cooler red.
So the egr valve itself doesn't have cooling water connections.
