Home > Technical (L322) > 4.4 V8 O2 sensors - Plus new fault: 48C Electric thermostat
Lenb
England 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Can anyone read the attached logs - attached as a photo. I have a downside O2 sensor fault but trying to understand if this is causing my starting issues.
 Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Previous: 2000 P38 DHSE - 1995 P38 DT Man - 1990 3.9 SE Classic, 1980 3.5 Classic 2dr
Post #386373 11th May 2016 1:42pm
half way down , i think the polygraph is saying that you are lying.... Mr. Green
sorry i have no idea what all that means but someone will be along soon to explain.. Thumbs Up ... - .- -.
Post #386382 11th May 2016 2:04pm
Lenb
Rolling with laughter Rolling with laughter
Very good Smile
Hopefully so, if it is what's causing difficult starting then maybe a new O2 sensor will do the trick.
Thanks! Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Post #386405 11th May 2016 2:38pm
O2 sensors have little to no effect on starting... but knowing what FF's are like I'd eliminate all the errors you can find first....
Whats your starting issue...??? Pete
Post #386427 11th May 2016 3:53pm
Lenb
My starting issue is as I have mentioned in my other post, difficult when engine hot. Fails at first attempt or splutters to start. I think it was you Pete that suggested injectors and I must admit it's sounding more like it - flooding due to wear/leaking. I decided to do a fault check and this is what came up with:
0x404 O2 sensor heater circuit bank 2 downstream sensor fault
0x414 O2 sensor circuit bank 2 downstream sensor
I also did some live readings to see if anyone on this forum could help. I do most of my own repairs but each one is a learning curve. Trying to find as much info as possible before spending more money.
(Sorry if I was wrong starting another thread)
Len Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Post #386436 11th May 2016 4:22pm
Len,
My mistake, been away a couple of days.... I haven't got the IID Blutooth so not to sure what they are showing... lambda sensors should alternate between high and low constantly after the vehicle gets up to temp and the system goes closed loop... I think that's around mid 80's on a FF....
As I said can't see a faulty sensor effecting starting... maybe worth wipping out a plug next time it won't start and seeing if it's wet.....??
When you say it won't start does it just take a long time or will it just do nothing until it cools...??? Pete
Post #386446 11th May 2016 4:33pm
chex
Kenya
That's a wiring fault. Had the same when I bought Lucas sensors and the plug fell apart in a couple weeks. Wouldn't affect starting. 2004 L322 V8
Post #386448 11th May 2016 4:34pm
Lenb
Haylands wrote:
Len,
Pete, it turns over and after a longer time than normally fires but 'splutters' in to life - occasionally then stalling, but other times picking up and running ok. If it does stall it starts fine on 2nd attempt (as though it's dumped the excess fuel?) Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Post #386453 11th May 2016 4:41pm
That really does sound like the old Rover V8's when the injectors started to fail, never heard of it on our's but I suppose it's possible... maybe worth getting them checked..... Thumbs Up Pete
Post #386461 11th May 2016 4:57pm
Rangeyman
Just an outside chance it could be a bad connection,try removing any electrical connectors to the sensor and a little electrical spray .
Post #386518 11th May 2016 6:25pm
Lenb
Bad connection
I will try this when its dry (no garage) - might at least save my buying a sensor needlessly. Smile
And main stealers want £169 + vat Big Cry Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Post #386522 11th May 2016 6:30pm
Lenb
Remove and clean connectors + 1 extra fault
I removed and cleaned and not really made any difference apart from only getting one of the O2 faults! However today I did another fault read and got 48C Electric thermostat circuit fault. Cleared all faults and this has not returned. Checked live Temp at tick over after arriving home and coolant temp remained around 104 degs with radiator coolant temp around 55 degs
Post #386846 13th May 2016 11:43am
Re: Bad connection
They are Bosch ones, I got a vehicle specific one from a motor factor for about £40... I do get trade discount but it should still be much cheaper..... Thumbs Up Pete
Post #386904 13th May 2016 5:28pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
The downstream O2 sensors (B1S2 & B2S2) have no effect on running of the engine. They are merely there to check the efficiency of the CATs. Once the CATs have warmed to their operating temperature and the system enters closed loop the downstream O2 sensors should show a fairly steady graph with very few spikes (it will move with rpm/load changes). If the downstream sensor matches or oscillates wildly like the upstream sensor then it indicates the CAT is doing little or nothing to the exhaust gases (assuming it's warmed up, older CATs may take longer or higher revs to get hot enough to work).
If the downstream O2 sensor is flat line all the time it indicates a possible fault with the sensor, either the sensor itself or it's heating circuit could be an issue. The wiring then needs to be checked at the sensor before condemning the sensor itself.
Again though, it has no effect on the running of the engine, the downstream O2 merely report CAT efficiency and flag an error if outside the limits.
I assume the graphs are Upstream and Downstream O2 sensors? It looks like that was with the engine warm? In which case I can't see an issue assuming the oscillating traces are Upstream and the more uniform traces are Downstream.
It could be an intermittent fault that has thrown up the O2 codes.
As for your hot start issue, as you suspect and has been mentioned by others, it most probably indicates a fueling issue (over or under fueling due to injectors or supply issue) or possibly electrical with a component breaking down under heat soak (crank sensor) although I would expect it to also fail when running and hot (stalls) and would also hopefully give error codes. For that reason, and it's fairly easy, I would be checking fueling first.
I would check fuel pressures on hot start to rule out supply problems, if it checks out (compare to cold start, just turn the ignition on and compare how quick they reach max pressure) then use a scope to check the voltage trace of the injectors to see if they are firing correctly.
Cheap and dirty, hope and pray but wont hurt, run with some injector cleaner for awhile.
Post #387057 14th May 2016 12:11pm
Lenb
Weejock - thanks for the explanation re O2 sensors. The graphs are just Bank 1 Lambda Control & Bank 2 Lambda Control - and its bank 2 that's coming up as a fault, which is also the bottom graph, (from the drivers seat, which is bank 2?).
I have put in some injector cleaner (after all there is nothing to loose) and next week I will be checking the fuel pressure - will update when I know more.
Thanks for everyone's help so far Smile
Post #387162 14th May 2016 10:05pm
