![]() | Home > Technical (L322) > TDV8 no power, white/blue smoke |
| MattChaloner Member Since: 12 Oct 2014 Location: Corsham, Wiltshire Posts: 53
Hi all,
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1880
If there is oil in the downpipe, the turbo is most likely |
Hi Mikey,
Always replace the engine oil and filter, as well as the oil feed pipe. If both turbos are being replaced, it an extra half hour or so to replace it |
Quick update, the O/S turbo seals have gone and the N/S is totally |
So here's a photo of the N/S turbo - Correct me if I'm wrong, but shouldn't that shaft in the middle have a nut on the end? If so I guess we need to start playing hunt the nut, not sure if the engine would have enough draw to suck something that size all the way into the engine but don't want to take any chances? 3 litres of oil came out of the intercooler when removing the lower pipe, so that will be coming off anyway. Hopefully it hasn't got any further.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786
Nah that's fine that |
| rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119
Hi rar, hopefully I can put your mind at rest a bit here:
Thanks mate. Mine has 250,000km. I was of the same mind re high mileage and value. I was anticipating having to spend some money. But like your car, many things had already been done.
Just another quick update, the nut hadn't gone far at all - It had simply dropped forward into the induction pipe and when it reached its lowest point it settled there. Found within 3 minutes of looking! Presumably the nut wasn't able to get sucked up and through because the turbo had failed in such a way that the turbo wasn't creating any pressure.
| theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305
Did you get her up and running? |
To an extent yes... All turbo stuff finished on weds, but was still pouring out blue smoke from the exhaust full of oil. Got it recovered by a friend to a quiet area and got it hot, drove it around for 20 mins or so until the smoke went. Took it for a 140 mile round trip down to our caravan in Dorset for the weekend and it performed beautifully apart from a slight hesitation around 1500rpm.
| jscanlan_001 Member Since: 16 Sep 2016 Location: UK Posts: 2
one of my turbos gave up so looking at replacing both, it's either a garage or do it myself. How long did it take you to replace them? I'm handy with spanners and have a good idea of what I am doing. Did you need to get the RR on a ramp or were axle stands enough? |
