![]() | Home > My Range Rover > Just got my first FFRR! 2003 Vogue 4.4 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8394 ![]() ![]() ![]() |
They are sent to try us... take a fresh look in a day or two and it may help.... |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
Just got my iCarsoft tool and jack pad. I hope the weather lets up enough to let me get the transfer box motor on and get testing.
The iCarsoft tool is really useful! I can show live data like the transfer box motor potentiometer resistance, when the switch is calling for a range change etc. as well as codes!
Electric thermostat circuit fault, is probably the plug that plugs into the engine thermostat it's not that important and does very little... especially if you do the thermostat upgrade to the 80deg one...
Locks are OK, just the key doesn't open/lock from outside. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Search for re-synch key threads, it's quite easy, but read the process two or three times, as it's sort of hard to 'do it' first time..
John, I think he means the physical key, not the remote.... |
Yes, the physical key not the remote. I suspect the typical BMW lock failure. |
This morning so far - pollen filter and air filter done. The pollen filter was in backwards and full of tree droppings! Britpart pollen filters do not have a flow direction on.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Fix the lock as a priority as the only way in when battery fails |
I gave up with the suspension. Having discovered that Halfords don't sell and 18mm socket I'm going to get Aylmer to do it when they do the exhaust.
The door lock turned out to be the easiest fix so far. The lock itself has a thing on the end kind of like a cross-head screwdriver which engages with a microswich in the door. The part that connects to the barrel has some movement in it, a bit like a wobbly extension. So, when the lock is inserted, it drops down under the microswitch. It just needs guiding in with the door panel off, now it works fine! |
I'm getting the feeling someone who didn't quite know enough has been playing with your FF in the past...
Most of us, have a few problems, getting our new toy into proper running order. And you know to yourself, that each bit is checked and done. Whilst checking these bits, we have opportunities to check other things, like brake pad wear, and small rust areas , and gremlins. Don't worry too much about getting a long list. Not all the jobs you talk of are necessary, some are cosmetic..
