![]() | Home > My Range Rover > Just got my first FFRR! 2003 Vogue 4.4 |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
Ah, yes, I see!
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8513 ![]() ![]() ![]() |
Was nice to meet you Ian, shame you chickened out bringing the FF with you..... |
Cheers Pete,
Tuesday night I used the FF with no errors at all! I actually started to enjoy it. I finished off painting the cup holder (pics soon) which looks pretty decent. I have to work out how to remove the surround for the entertainment system at some point and paint all the other foundry trim.
That should sort a lot of the faults out... |
Ah, I see - not too hard then. I'll see if I can do it at the same time as the pixel fix (at some point...).
Yesterday, I picked up the car (truck?) from Aylmer, who did an oil and filter change, transfer box drain/fill and checked over everything. Brakes and bushes are in good order, which is good. They also supplied a rad and coolant as they didn't have time to change them, but having not ordered the trans cooler I thought I may as well do it myself this weekend. It's booked in for a week's time to drop and weld the exhaust.
Getting there.... |
I'm done for the day now |
Oh ****. Front wheels have locking nuts. No key and my local BMW and RR dealers are closed tomorrow. I was hoping to finish the service items (remove/grease wheel mating surfaces) tomorrow and start getting some penetrating spray on the knackered front strut. Bah. |
EAS fault may or may not be a hard fault, a battery disconnect may sort it, worth a try....
Well, I ordered the iCarsoft code reader thing for £90, since I can't afford an IIDtool at the moment. I'm a little concerned about removing the bottom strut bolt as I seem to have little luck when it comes to shearing bolts. Today will be mainly washing it and starting on some more of the interior cosmetics. |
A good wash and brush up showed up lots of swirly paint, a poorly repainted rear O/S door, poorly repainted drivers' door shut, missing rear door lower arch seal and a rotting foglight reflector. Oh and one tyre looks really low, despite being up to pressure. Which is odd.
Getting frustrated now. Took off the transfer motor, opened the pot to find the expected wear under the contacts, so I bent them across a little. All looked good, put it back together, back in the car. For some reason the "fat spline" was 180 out on the box. As far as I could see the gear must have been rotated somehow - I don't know how - and when I rotated it back in it was 180 degrees out. So I rotated the motor, refitted, got a couple of OK shifts to high/low then got a grinding noise, trans failsafe, and packed it in. I think when the thing failed last time the transfer box wasn't quite in gear.
