![]() | Home > My Range Rover > Just got my first FFRR! 2003 Vogue 4.4 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8514 ![]() ![]() ![]() |
Tried them all, found these to be the quietest and have the best clearance in all conditions plus less wind noise... last a long time as well... |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3217 ![]() ![]() ![]() |
Spot on Pete. altho mine were only £15.95.
Available all over the place, I actually got mine locally last time...
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
I'm happy with the Bosch wipers - I read about the flat ones, but I've always used Bosch on my previous fast cars (Porsches, Maserati) so with the good deal I went with them. They work perfectly.
Can't knock Bosch wipers they are very well made, it's just the flat blade ones are so much better technology, no noise on the screen, reduced wind noise, no fishtailing in cross winds and don't lift at speed.... |
It's close (I hope). The remaining list, for anyone that cares |
I'd do the balance and alignment pretty quick, if your steering wheel is off center it can upset the steering angle sensor and cause problems, and both can cost money...
Tyre and balance should be today - it would have been last week but Blackcircles lost the tyre and had to order another! Steering wheel isn't miles off, and the car tracks straight, and front tyre wear is even so I'll get to that at some point. |
Tyre changed at a local garage. I was impressed that he used a torque wrench to tighten the wheel nuts, not so much that he stood there with the door open waiting for the suspension to raise - "I know all about these"... no, you don't!
I'm visiting a customer in Switzerland, so left the beast in a Heathrow car park. Will it start after 3 days of being ignored? We'll see!
After 3 days at Heathrow it started just fine, which was nice after a 3 hour delay. I've done some small jobs in the meantime:
Getting there.... |
Yup, that will be the end of the service items - well, maybe balance the other wheels - and the main upgrade I wanted. I still have some small cosmetics to do, but that's more for my own satisfaction. Paintwork is a bit tired, but that's another matter.
