Home > Technical (L322) > A Bar Spotlights |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Lights have a dedicated fitting wiring kit sir. That way you can turn them off when either not necessary on the road or weather dictates |
5th May 2016 9:33pm |
CharlieBaja Member Since: 01 Feb 2016 Location: Surrey Posts: 52 |
I have the wiring just want to know if i can piggy back them off the main headlight beam |
5th May 2016 9:47pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
If you are going to do it, I suggest fitting a relay into the main beam wiring to detect current and activate it to switch on the spots. Whether this will impact on the operation of the main beams and ECUs I do not know....
5th May 2016 10:28pm |
As i said above... LR make a L322 spotlight wiring kit specifically to fit LR spotlights (or any for that matter) which includes a switch and all the connections... If it were me, i would purchase and fit that sir... |
5th May 2016 10:43pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
Don't think you would want the lightbar on the roof on much of the time anyway, lights up there cause so much glare off the bonnet that they don't help much whilst moving and most of the time make it worse.... Pete
6th May 2016 12:04am |
I only really want the roof light bar as it looks good on the Bond SVR |
6th May 2016 5:32pm |
Oh, right, I get it...
6th May 2016 6:04pm |
Timbo Member Since: 11 Jun 2015 Location: Gods Own County Posts: 11 |
Bottom one is a tarts handbag - yours looks far better Pete... |
6th May 2016 8:16pm |
I am guessing with that comment you don't like the SVR look alike and especially with the light bar? |
6th May 2016 9:33pm |
Oh b**ger Charlie - not yours is it? In which case no offence intended 😳
6th May 2016 9:53pm |
No mine is the one on three wheels, i just like the light bar ontop!! |
6th May 2016 9:55pm |
Lol fair enough! Could always do a matt black wrap on the bonnet to reduce the glare I guess.... |
6th May 2016 10:08pm |
that's what i was thinking |
6th May 2016 10:10pm |
Have a look at EDF post on the EDF shopping cart. He put a really top notch light bar on for the Swedish winters, he may be able to give you some pointers on do's and don'ts MY 2010 5.0 SC Galway green and sand interior!!
7th May 2016 8:10am |
