![]() | Home > Maintenance & Mods (L322) > Car Detailing: How to achieve amazing results @ Home |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2052 ![]() ![]() |
swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69 ![]() ![]() ![]() |
Great info, What is best for rubber floor matts ?
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
I use autoglym vinyl and rubber care for the mats |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Can't find the Meguairs 3 Stage Paint kit on the Meguairs site. Can someone indicate the three products required? .
bump? .
twhincup Member Since: 22 Feb 2012 Location: byfleet Posts: 109 ![]() ![]() |
this should help:
5IMON Member Since: 27 Nov 2011 Location: London Posts: 165 ![]() |
Woolite does wonder for leather-google it |
OK just ran a test on bringing up a great looking finish (not on an FFRR just yet)
I've used 2000 grade emery paper on car paint work before polishing.
vince Member Since: 19 Feb 2013 Location: Gt Manchester Posts: 12 ![]() |
This needs to be taken with a pinch of salt....true in so far as machining whilst holding the handle doesnt give you the same finite control as holding the machine as if it wasnt fitted, but the D handle if left in place does allow you to put down your machine without it rolling over and picking up grit onto the pad ![]() ![]() Vince - Pallas Auto Refinishing |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Having less and less time means the weekly Saturday routine for keeping our two cars clean is getting harder to fit in. I usually pressure clean, shampoo and towel dry. I also clay bar and wax every 6 mths. As the cars live outside I often have to give them a wipe over to deal with bird and bat droppings before they eat into the paint.
LROMAD Member Since: 10 Oct 2015 Location: Cheshire Posts: 54 ![]() ![]() ![]() |
A good tip for those thinking of using an electric( or air polisher.) To protect the edges /swage lines on panels,we use 3M fine line tape. Comes in 2 widths 3mm and 6mm .Carefully stick it ( raised ) areas before polishing.You can polish over it ,as you do the panel. Comes off easily.Available on e bay about £5 a roll/ 36 yds long.. |
