Home > Maintenance & Mods (L322) > Car Detailing: How to achieve amazing results @ Home |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2037 |
my secrets out
5th Feb 2011 6:53pm |
swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69 |
Great info, What is best for rubber floor matts ?
14th Aug 2011 9:00am |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 |
I use autoglym vinyl and rubber care for the mats FFRR TD6 HSE
14th Aug 2011 9:12am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
Can't find the Meguairs 3 Stage Paint kit on the Meguairs site. Can someone indicate the three products required? .
25th May 2012 11:05am |
bump? .
27th May 2012 11:12am |
twhincup Member Since: 22 Feb 2012 Location: byfleet Posts: 109 |
this should help:
27th May 2012 10:06pm |
5IMON Member Since: 27 Nov 2011 Location: London Posts: 165 |
Woolite does wonder for leather-google it |
27th May 2012 11:15pm |
OK just ran a test on bringing up a great looking finish (not on an FFRR just yet)
2nd Mar 2013 12:01pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
I've used 2000 grade emery paper on car paint work before polishing.
2nd Mar 2013 12:22pm |
vince Member Since: 19 Feb 2013 Location: Gt Manchester Posts: 12 |
This needs to be taken with a pinch of salt....true in so far as machining whilst holding the handle doesnt give you the same finite control as holding the machine as if it wasnt fitted, but the D handle if left in place does allow you to put down your machine without it rolling over and picking up grit onto the pad I dont have one fitted on my rotary as it doesnt tend to roll over, but have left it on on my DA for that exact purpose. I dont use it when machining though Vince - Pallas Auto Refinishing |
3rd Mar 2013 10:29am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Having less and less time means the weekly Saturday routine for keeping our two cars clean is getting harder to fit in. I usually pressure clean, shampoo and towel dry. I also clay bar and wax every 6 mths. As the cars live outside I often have to give them a wipe over to deal with bird and bat droppings before they eat into the paint.
29th Apr 2016 11:52pm |
LROMAD Member Since: 10 Oct 2015 Location: Cheshire Posts: 54 |
A good tip for those thinking of using an electric( or air polisher.) To protect the edges /swage lines on panels,we use 3M fine line tape. Comes in 2 widths 3mm and 6mm .Carefully stick it ( raised ) areas before polishing.You can polish over it ,as you do the panel. Comes off easily.Available on e bay about £5 a roll/ 36 yds long.. |
30th Apr 2016 6:50am |
