Home > Maintenance & Mods (L322) > fuel additives
Page 1 of 3 123>
rangeseb
United Kingdom 2006 Range Rover Vogue Td6 Java Black
fuel additives
Hello all,
I haven't used a fuel fuel additives since Dec 2015 and would like to give it a go again.
I was using Redex Diesel Treatment 500ml over 2 tank fills but was wondering if i should continue to use the same brand or is there something else i could treat the car too or better yet dont use any other them? Confused ..
tanks in advance
Post #383702 25th Apr 2016 1:54pm
rangeseb
After doing no work today, i have seen this product (below) is the one the internet says is good.
Post #383732 25th Apr 2016 4:42pm
BG244 diesel cleaner is also well regarded. Thumbs Up
http://bgprod.co.uk/products/fuel-and-air-intake/bg244. There is nothing that can't be fixed with a hammer😜😜
Post #383737 25th Apr 2016 4:55pm
miggit
Yesterday I was doing some research in to VW Touareg Turbo problems.... and I discovered that they are very common, and that by adding some 2 stroke oil in to the fuel these problems can be reduced / fixed Shocked So having seen this post, do you think that I can find the page again Censored Censored ..... But I did find this..... bit of an eye opener..... think I'll give it a shot, or should that be 2 shots Laughing Laughing
http://www.brick-yard.co.uk/forum/adding-2...37935.html Yesterday I couldn't spell Engineer... Today I are one!
Post #383813 25th Apr 2016 10:34pm
Digger7820
United Kingdom 2002 Range Rover Vogue Td6 Rimini Red
I used 2 stroke oil in my Defender TD5 and it ran a lot better sounded better and when i took it for MOT the emissions where a lot lower than the past two years !! Cool Cool Range Rover vogue Td6
Land Rover Defender TD5
Grand Jeep Cherokee
Discovery 300tdi
Discovery 200tdi
Series lll short wheel base
Super 7 kit car
AC Cobra (still got)
Post #383815 25th Apr 2016 10:50pm
Zain
Ive been using this Millers additive on my bmw e92 325d for the last 3 fill ups and have noticed the engine to be slightly quieter and also less smoke/soot out of the exhaust on start up. All based on observation rather than any technical/quantitative measurements.
Post #383816 25th Apr 2016 10:51pm
miggit
Just been doing some more 2 stroke diesel reading and the general consensus of opinion is use MINERAL or MINERAL + Synthetic.... but never fully synthetic, as it don't mix with the fuel and costs shed loads more.... Cheap is best Shocked Shocked Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #383818 25th Apr 2016 10:54pm
Discotigger
I always used a bit of 2 stroke oil in my old 300TDI Discovery, it ran much better and kept everything cleaner in the engine department. Never used it on the fatty though, as have tended to use the Diesel Injector Cleaner additive instead. May give it a go, though, as I do around 500 - 600 miles per week.
Post #383858 26th Apr 2016 11:39am
mzplcg
Oil and logs. Fantastic combination Thumbs Up
Erm, on the serious side, there is a whole (long) thread on Disco3 about the use of 2-stroke in diesel. The BG244 stuff is a well regarded fuel system and engine cleaner but they have a different product for regular use. I think 244 is too strong to use all the time.
http://www.disco3.co.uk/forum/topic82489.h...stroke+oil
Post #383869 26th Apr 2016 1:02pm
yes they recommend BG244 every 7500 miles. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #383903 26th Apr 2016 3:49pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Millers only needs a capful per fill up which is a considerable saving over Redex.
They also do a treatment for EGR valves which can be used in small doses as a preventative or in a single hit for a clean out.
The argument on whether or not the diesel additives are any good or not is as big a can of worms as the argument on supermarket fuel versus premium fuel.
Post #383918 26th Apr 2016 4:35pm
Show n shine
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
I use liqui moly super diesel additive. And liqui moly diesel purge. Great results as I use it in my td6. German quality Cool
Post #390199 4th Jun 2016 4:29pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I would not but two stoke oil in any vehicle I want to keep....http://www.fuelexpert.co.za/2-stroke-oil-i...-study.php 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #390234 5th Jun 2016 2:04am
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
I've just started using CRD by Cost Effective Maintenance.
Was a bit dubious, but I'm amazed at the difference even the first dose has made.
Engine is noticeably quieter and less 'rattley'
Post #390235 5th Jun 2016 2:43am
Mikey
Report was compiled by Adrian Velaers, of Sasol Energy Technology. A company with large interests in commercial oil + gas
Show me a fully independent report, not subsidised by an O+G company Wink
FWIW, I run it in my D3, Td5 Defender and the wife's FL2, as well as a few previous cars. Every one has run smoother, quieter and improved fuel economy by a small amount, as well as produced less smoke. And, with current ULSD, any additional lubrication going back into the fuel system can only be a good thing Thumbs Up
Post #390239 5th Jun 2016 6:07am
Page 1 of 3 123>
