![]() | Home > Maintenance & Mods (L322) > fuel additives |
rangeseb Member Since: 06 Nov 2015 Location: Baldock North Hertfordshire Posts: 185 ![]() ![]() ![]() |
After doing no work today, i have seen this product (below) is the one the internet says is good.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8683 ![]() ![]() ![]() |
BG244 diesel cleaner is also well regarded. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Yesterday I was doing some research in to VW Touareg Turbo problems.... and I discovered that they are very common, and that by adding some 2 stroke oil in to the fuel these problems can be reduced / fixed |
Digger7820 Member Since: 04 Jan 2016 Location: Brigg Posts: 28 ![]() ![]() ![]() |
I used 2 stroke oil in my Defender TD5 and it ran a lot better sounded better and when i took it for MOT the emissions where a lot lower than the past two years !! |
Zain Member Since: 17 Apr 2014 Location: London Posts: 98 ![]() ![]() ![]() |
Ive been using this Millers additive on my bmw e92 325d for the last 3 fill ups and have noticed the engine to be slightly quieter and also less smoke/soot out of the exhaust on start up. All based on observation rather than any technical/quantitative measurements. |
Just been doing some more 2 stroke diesel reading and the general consensus of opinion is use MINERAL or MINERAL + Synthetic.... but never fully synthetic, as it don't mix with the fuel and costs shed loads more.... Cheap is best |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
I always used a bit of 2 stroke oil in my old 300TDI Discovery, it ran much better and kept everything cleaner in the engine department. Never used it on the fatty though, as have tended to use the Diesel Injector Cleaner additive instead. May give it a go, though, as I do around 500 - 600 miles per week. |
Oil and logs. Fantastic combination |
yes they recommend BG244 every 7500 miles. |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
Millers only needs a capful per fill up which is a considerable saving over Redex.
Show n shine Member Since: 01 Jun 2016 Location: Hertfordshire Posts: 55 ![]() ![]() ![]() |
I use liqui moly super diesel additive. And liqui moly diesel purge. Great results as I use it in my td6. German quality |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
I would not but two stoke oil in any vehicle I want to keep....http://www.fuelexpert.co.za/2-stroke-oil-i...-study.php 2007 TDV8 VSE
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
I've just started using CRD by Cost Effective Maintenance.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1786 ![]() ![]() |
Report was compiled by Adrian Velaers, of Sasol Energy Technology. A company with large interests in commercial oil + gas Show me a fully independent report, not subsidised by an O+G company ![]() FWIW, I run it in my D3, Td5 Defender and the wife's FL2, as well as a few previous cars. Every one has run smoother, quieter and improved fuel economy by a small amount, as well as produced less smoke. And, with current ULSD, any additional lubrication going back into the fuel system can only be a good thing ![]() |
