Home > My Range Rover > Just got my first FFRR! 2003 Vogue 4.4 |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
Have you done or considered doing a sniff test on the engine coolant? |
19th Apr 2016 6:45pm |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
Aylmer suggested that. Still, with no oil or bubbles in the coolant, and no mayo in the oil, I'm inclined to fix the fan first anyway since it's clearly not working properly. It's booked into them in a couple of weeks for a service/diag session anyway, so I should fix the obvious bust stuff I think before then. |
20th Apr 2016 10:32am |
Well I hoped. I changed the fan clutch, which was definitely knackered. Same problem though, gets hot, comes down... up... next step has to be a rad I reckon.
20th Apr 2016 1:16pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8340 |
Stop chucking money at it, get a diagnostic tool and read off some live values... Pete
20th Apr 2016 9:50pm |
Last night I got to reading more stuff about the M62 cooling system. There are two potential issues generally - lack of coolant circulation, or lack of airflow. Replacing the fan clutch should have dealt with airflow, so what about circulation? Bakc to thoughts about rad/stat/water pump... but what about a simple airlock? So having read the WSM and watched a Youtube vid on bleeding the system, I thought I'd give it a try this morning.
22nd Apr 2016 8:38am |
I just leave it ticking over with the header tank top off.. sorts itself out after a while, then check it when cold after several trips over a few days... they can be a pain to do.... Pete
22nd Apr 2016 11:43pm |
After running around yesterday, the level seemed OK this morning. I'm still bothered by the level indicator not working. New expansion tank on order! I'll do a flush and refill at the same time.
23rd Apr 2016 12:05pm |
If you are looking for interior paint to match the foundry grey paint I got some made up by these people which is a good match.
23rd Apr 2016 12:16pm |
Actually I meant paint to match the cream/parchment colour. The tailgate trim and C-pillars are a bit scratched up, so I thought I'd paint them if I can match the colour. I'll worry about the foundry colour some other time - actually, I was thinking about using a darker colour as I think it might look nice. I have a few odd cans I've used restoring another car, so might just hunt around the garage and see what takes my fancy! |
23rd Apr 2016 2:52pm |
23rd Apr 2016 2:54pm |
Monitoring the coolant level seems to show it's OK on petrol. I tried briefly on LPG and will check the coolant level to see if the vapouriser is leaking gas into the coolant, and would therefore need a diaphragm kit. While using LPG I get an occasional stumble, which I'm surmising is a clagged filter, so I'll book it in for a service and check over (and to get a stamp in the book).
26th Apr 2016 8:10am |
Tried to go out this evening. Mad bonging, looked like I was stuck in low range and no amount of fiddling with the connector made any difference. Limped home, parked up, got "apply handbrake" and "key battery low" messages, couldn't lock the damn thing. Took my wife's car
26th Apr 2016 10:05pm |
I took my wife out for a short shopping trip this afternoon and all was fine. Later, we went to get my daughter form school, and sat in the car park for about 15 minutes with the engine off, but mucking about with the audio system. When we moved off again, BONG BONG with "transfer box neutral" messages all the way home (25 mins or so). Engine off when home, then started again to park up and all was OK! Changed range a few times, and it all worked. Then later, another short-ish trip to drop my wife at a local meertng and everything was fine, went to pick her up later and another couple of warnings.
27th Apr 2016 9:10pm |
With some renewed enthusiasm after meeting Pete (Haylands) over the weekend, I decided that the battery was somewhat under the weather, since it dropped from 12.1 to 11.3v over night, and didn't charge on a 30 min drive. ECP have a 25% discount this weekend, so a Bosch Silver 020 replaced the unbranded 019 that was fitted.
2nd May 2016 2:31pm |
