![]() | Home > My Range Rover > Just got my first FFRR! 2003 Vogue 4.4 |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
Following on from here: http://www.fullfatrr.com/forum/topic37080.html
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7896 ![]() ![]() ![]() |
Bit like when you get any used car really. It's now the worst it's gonna be in your ownership and will only get better.... Just takes time.....
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8513 ![]() ![]() ![]() |
Welcome to the world of L322's...
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Most of your faults are common and easily fixed (use the search facility) but most worrying is the temp gauge & air pump sir... Sounds like a poor LPG kit fitting has taken place |
Thing is, it doesn't do it all the time. From looking at the shop manual, and threads on various forums, it points to the ECT sensor or wiring. I'll track the temp on the diag display and see if they match. It moves too fast to be real, I feel, having had cars that overheated in the past. The LPG is a BRC system with a proper certificate, and the pump is located fine, and has some insulation around, but it's just not on any kind of bracket which I understand is not unusual.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3217 ![]() ![]() ![]() |
Spock, the rear wiper on my first FFRR (2002j didn't park against the glass either. I think it was designed like that as it wiped perfectly on the way down. It also means that the rubber doesn't get perished or stuck to the window glass! |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
At the LPG service, ask them to check condition of the rear water hoses. They are a bugbear of this engine. And they will have been adapted to fit the LPG.
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
Rear wiper will be seized up on the pivot.
Interesting... the coolant level is fine, but it has sparkly bits in which suggests that someone's tried a leak fix. The service history shows two water pumps in the last 40K miles. The ECT sensor wiring looks fine too. So I'll keep an eye on it and get it booked in asap for an oil service and coolant flush, and the LPG service and get them to check the hoses.
A little progress. The Parrot thing has no switched live. Well, it's wired into the green/brown wire under the cup holder, but it's dead. Wiring diagram time... Ah, accessory socket fuse blown. |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
I'm six and a half months ahead of you. Major problems sorted under the 3 months read the small print warranty.
A little more this morning... A quick trip to Halfords for some fuses meant I could replace the 20A accessory socket fuse, and the rear seat heater fuse (again). I suspect that the switched live for the Parrot has piggybacked on the seat heater, so it all fails at once. I've neatened up the wiring and will see if it happens again. The accessory fuse blow was due to my hamfisted use of a 12V probe...
Stew 46 Member Since: 23 Feb 2016 Location: North cornwall Posts: 123 ![]() ![]() ![]() |
After owning land rovers for 20 odd years now , there's always some bits to sort out when you pick one up and get it home |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8744 ![]() ![]() ![]() |
^the fuel gauge problem on the 3.6 is a common one.
