Home > Maintenance & Mods (L322) > Anyone removed the Wiper arms on an L322? I have a question!
Ohwhatalad
United Kingdom 2013 Range Rover Vogue SE SDV8 Corris Grey
I ordered a couple of new wiper arms from Dan because mine were old looking and chipped.
Went to fit them tonight, took off the cover, and undone the nut no problems.
Pulled up on the wiper, came off really easy..too easy. Its seperated in 2 and left the bottom half stuck to the bolt coming out of the wiper motor.
Luckily i was prepared, i bought a Sealey windscreen arm removal tool just for this job, although its a mm or 2, too short for the ranges massive bolt. i got it on kind of, half, but it still wont budge. Ive used WD40
but my question is, who has removed these and how did you do it, is there a trick or special tool you used at all?
ive added a few photos of the little buggar
Post #375142 1st Mar 2016 6:14pm
miggit
Shocked Why do you need to remove those bits? your replacing the wiper arms, not the shafts, aren't you? Can't you leave the old base on the shaft and use the new upper half that came with the wiper, it would save a lot of Banging Head Yesterday I couldn't spell Engineer... Today I are one!
Post #375147 1st Mar 2016 6:33pm
Ohwhatalad
You know what, i havn't even looked at the new wiper arms properly but they looked pretty well sealed together, i just thought i had broken the old wiper arm base in half and left this half on the splines still! i shall look though Bow down
Post #375148 1st Mar 2016 6:35pm
miggit
Those bases allow you to adjust the angle of the wiper arm, so that you can get it just right, Whistle I believe that there is an optimum angle that they run at 89.1 or something like that, in other words just leaning in to the up sweep Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #375149 1st Mar 2016 6:39pm
Ohwhatalad
Unfortunately the new wiper arms come sealed by the looks of it, so that bottom metal bit on the spines needs to come off before the new arms are fitted
see the pic
Post #375151 1st Mar 2016 6:43pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
When I refurbed my wipers (sprayed them) I left the lugs in situ, and just gave them a good clean.
the ali oxodises. Put a dollop of grease on and refitted.
why do you need to remove them?
Greg.
sorry mate, wasn't typing fast enough from other replys. Laughing
Post #375157 1st Mar 2016 7:06pm
Ohwhatalad
Haha no worries. The lugs are fixed onto the new wiper arms ready.
Rave says to replace them when fitting new arms I guess to stop them getting so stuck on !
I would happily leave them if I could though !
Post #375163 1st Mar 2016 7:19pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
When I had to remove mine to re seat them in the correct position to stop the annoying thud at the top of the blade sweep I used a set of gear pullers like these
http://www.toolstation.com/shop/p79243
Only £18 quid odd and did the job just fine. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #375167 1st Mar 2016 7:36pm
Ohwhatalad
tried the gear pullers but they arrived and are too big to even get under the bit i need to remove.
im confused, please see my new and old wiper arm. the new arm is complete unit and has no thread as such to go onto the car so how will the wiper arm move when its on if theres no gear like mechanism on it?
im going to grind the old part off the bolts on the car to fit new arms but need to make sure they will work before doing so
any help greatly appreciated
Post #382109 14th Apr 2016 1:45pm
Weegie
Looking at your first photos, I take it it's the white, ribbed part which you are trying to remove? I don't know but would they not screw off? John
GAP iiD BT
Post #382111 14th Apr 2016 1:55pm
Ohwhatalad
its metal but looks white, yes trying to remove it, i think it is on a spline rather than screwed on which is why i tried wiper pullers to pull it off, can anyone confirm?
Post #382112 14th Apr 2016 2:27pm
Ohwhatalad
well i found out the smooth bore on the new wiper is how its meant to be, as when you install it the spline cuts into the new wiper making the fitment nice and tight
now just to decide if i dare to try and cut them off, can't believe how tight they are on
Post #382118 14th Apr 2016 2:39pm
Mikey
http://www.fullfatrr.com/forum/topic35804.html
Laser 1793 Thumbs Up
Post #382131 14th Apr 2016 3:19pm
Ohwhatalad
thanks for that i will take a trip to halfords and pick one up, hopefully it gets them off!
Post #382132 14th Apr 2016 3:33pm
Had to use a puller on mine, had it tightened as tight as it would go before the central bolt started walking off the wiper shaft then had to bray hell out of it with a hammer to get it to pop off... Had to be very brutal.... Then the other one was a bit tighter
The parts should come off the new arms no bother and just fit the top bit's as has been said before...
Don't use copperslip on them, on reassembly, it will eat the alloy... regular grease will do... Thumbs Up Pete
Post #382157 14th Apr 2016 6:30pm
