![]() | Home > Maintenance & Mods (L322) > Anyone removed the Wiper arms on an L322? I have a question! |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Ohwhatalad Member Since: 27 Jun 2015 Location: Cambridgeshire, South East Posts: 191 ![]() ![]() ![]() |
You know what, i havn't even looked at the new wiper arms properly but they looked pretty well sealed together, i just thought i had broken the old wiper arm base in half and left this half on the splines still! i shall look though |
Those bases allow you to adjust the angle of the wiper arm, so that you can get it just right, |
Unfortunately the new wiper arms come sealed by the looks of it, so that bottom metal bit on the spines needs to come off before the new arms are fitted
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
When I refurbed my wipers (sprayed them) I left the lugs in situ, and just gave them a good clean.
Haha no worries. The lugs are fixed onto the new wiper arms ready.
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1754 ![]() ![]() ![]() |
When I had to remove mine to re seat them in the correct position to stop the annoying thud at the top of the blade sweep I used a set of gear pullers like these
tried the gear pullers but they arrived and are too big to even get under the bit i need to remove.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3260 ![]() ![]() ![]() |
Looking at your first photos, I take it it's the white, ribbed part which you are trying to remove? I don't know but would they not screw off? John
its metal but looks white, yes trying to remove it, i think it is on a spline rather than screwed on which is why i tried wiper pullers to pull it off, can anyone confirm? |
well i found out the smooth bore on the new wiper is how its meant to be, as when you install it the spline cuts into the new wiper making the fitment nice and tight
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1815 ![]() ![]() |
thanks for that i will take a trip to halfords and pick one up, hopefully it gets them off! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
Had to use a puller on mine, had it tightened as tight as it would go before the central bolt started walking off the wiper shaft then had to bray hell out of it with a hammer to get it to pop off... Had to be very brutal.... Then the other one was a bit tighter
