Home > Technical (L322) > Dash warning triangle - low key fob battery
BlackPerth
Australia 2017 Range Rover Vogue SE SDV8 Mariana Black
Hi guys I have the orange triangle warning sign re low battery in key fob on my dash so I changed the battery in the key fob but the warning keeps coming up. Anyone Know if i can remove using a GAP IID tool?
Cheers 2017 Range Rover Vogue SE SDV8 (with e-diff)
2012 Range Rover Vogue TDV8 Luxury (SOLD)
2010 Land Rover Discovery 4 3.0 TDV6 HSE Stornoway Grey (SOLD)
2006 Land Rover Discovery 3 SE 2.7TDV6 Black, G4 Challenge Copy (gone)
Post #381966 13th Apr 2016 10:47am
could be as simple as a battery disconnection.......unless theres something in the menu that can do it. ... - .- -.
Post #381967 13th Apr 2016 10:52am
BlackPerth
Yes I was going to do that but thought surely GAP tool would clear it...but it hasn't Crying or Very sad 2017 Range Rover Vogue SE SDV8 (with e-diff)
Post #381971 13th Apr 2016 11:49am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Do you keep the spare near the car? Mine was doing this the other day when SWMBO had a spare in her handbag, so we had 2 keys in the car. Obviously the new battery could well be crap?
Post #381995 13th Apr 2016 2:24pm
CS
I recall a post on here a while ago in which the first (cheap) battery didn't solve the problem but a Duracell one did. Only Range Rovers since 1988
Post #381998 13th Apr 2016 3:52pm
Helios
See the notes below it's a Dealer Special Service Bulletin I found on another forum... The advice given to press twice worked for me.
Issue
When the " Smart key battery low" message is displayed in the instrument pack message center dealers are complaining that after a replacement battery has been fitted the message does not disappear. The dealer then replaces the key in the belief that the key is faulty.
Cause
Dealers are swapping batteries from known good smart keys to diagnose battery low message or fitting aged batteries off the shelf. The message is displayed when the smart key voltage threshold has dropped below 2.44 volts. The message will clear if the smart key battery threshold is higher than 2.95 volts.
Note: these voltages are only measurable when the battery is inserted in the smart key.
Action
When the " Smart key battery low" message is displayed in the instrument pack message center dealer technicians and customers must fit a NEW still in the packet battery.
Under no circumstances should you swap batteries from a known "good" smart key.
LR part number is YWK10003L. (battery type CR2032)
Please note: CR2032 batteries stored in high humidity +75% & at high ambient temperatures greater then (+25degC) will greatly reduce its shelf life.
After replacement of the battery two smart key authentications need to take place to clear the message and to recognize the new battery voltage.
This is achieved by pressing any button on the smart key twice.
If the "Smart key battery low" message does not clear in the message center fit another new battery and retry.
If the "Smart key battery low" message is still present please replace the smart key, submit an EPQR and retain the smart key and all associated batteries for investigation. Please label the original battery and replaced battery separately.
Post #381999 13th Apr 2016 3:55pm
BlackPerth
Thanks all - will try shiny brand new battery (not one that I admit was sitting in the drawer for a year) and see if it works.
cheers 2017 Range Rover Vogue SE SDV8 (with e-diff)
Post #382049 14th Apr 2016 5:25am
Stuart-
The only bit missing from this topic is how to get into the fob itself to change the battery. This Youtube video shows you how. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1982 Rolls Royce Silver Spirit in green
Spiffing wheel centre caps, L322 sill repair panels, etc
Post #486106 14th Aug 2018 7:09pm
