Home > In Car Electronics (L322) > How to... Fit Android Head Unit to 2002-2005...
Page 8 of 20 <123 ... 789 ... 181920>
Ohwhatalad
United Kingdom 2013 Range Rover Vogue SE SDV8 Corris Grey
Thanks for the replies.
I'm suprised nobody has wired in the sub to an amp already! I'll leave it till all the rest is working and then take a look at which 2 wires I'll need to use
Going to make a start tomorrow Smile
Post #381790 11th Apr 2016 6:32pm
If your old like me you don't want all that "thump thump thump"... I recon it sounds much better without it...... Thumbs Up Pete
Post #381792 11th Apr 2016 6:38pm
miggit
Surprisingly enough I'm really missing having a sub, in the new bus Sad It's not so much the Thump thump, but the lower notes are a bit tinny without out it Thumbs Up
Pete I've got this picture in my mind that you pop down to the local shop to change your Battery Accumulator every week..... Wink
Ohwhatalad, sorry bud I thought that you meant the wires from the new head unit Laughing What Pete says.... the L/R sub has a built in amp... but you need to send a signal over the canbus to turn it on.... to save a lot of Banging Head I would be inclined to bypass all the L/R wiring and connect an external amp directly to the speakers.... I haven't looked at the ffrr unit, but I wouldn't think it's beyond the wit of man to gain access to the internals and run in some external feeds Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #381814 11th Apr 2016 9:04pm
Ohwhatalad
im 27 and dont like the thump but the lower end does help the overall sound quality in my opinion!
will look into it a bit more after, thanks for the info didnt know the sub had an amp on it already!
not looking forward to the trim pulling Big Cry
Post #381816 11th Apr 2016 9:14pm
miggit
The L/R trim is fairly easy to remove..... Bloody Mercedes isn't..... the clips brake every time Evil or Very Mad Yesterday I couldn't spell Engineer... Today I are one!
Post #381817 11th Apr 2016 9:20pm
Ohwhatalad
Spent a couple hours on it today.
Got the wiring all done in the boot and fired it up. All working apart from one rear mid speaker which is very crackly. So think it's blown.
Apart from that all good. Tomorrow the trim comes out so I can run the cable in!
Post #381895 12th Apr 2016 5:03pm
Ohwhatalad
All in, i run a rca cable from the Camera input on the unit to the back aswell so when i get time ill have to look into fitting a universal reverse camera from ebay
i think i would just need to run positive from reverse light and a negative.
not sure what the reverse cable from the head unit is for though! main part is done at least Smile
Post #382016 13th Apr 2016 5:57pm
Well done... reversing wire is to tell the sat nav you are in reverse... not a massive issue so I didn't bother with it...
Yep, that's about it.. can pick one of each up going into the tailgate... Thumbs Up Pete
Post #382041 13th Apr 2016 9:26pm
Busa1400
England 2007 Range Rover Vogue SE TDV8 Santorini Black
Just to say that I am new on here, I have read the thread and it is very very good, I have a 2007 RR Vogue and want to change my head unit - i understand that this is difficult because of an Amp ?? - as i had a boot full of water and I am getting intermittent problems with the Nav and Phone
I am in West Yorkshire anyone advise of anyone who can supply and fit a replacement unit
Once again superb thread
Post #391388 12th Jun 2016 12:02pm
Sorry, won't fit your year because of the fibre optics, your only option is to repair what you have... Pete
Post #391422 12th Jun 2016 7:36pm
Busa1400
Thankyou - I thought that maybe the case.
I could do with someone who knows what they are doing have a look over it, do you know anyone i can take it too that can look at the electronics - it's silly things like I have to pair the phone every time I get into the car, it works fine but needs pairing etc
I think it needs a 'laying on of hands'from someone who knows what they are doing
Post #391485 13th Jun 2016 9:27am
nip848
United Kingdom 2002 Range Rover Vogue 4.4 V8 Giverny Green
Thanks for this write up Haylands, this was an absolute godsend when I set about installing mine. Two of us over two days and the job is done Smile
I went for the android head unit, DAB tuner, Digital TV and a wifi reversing camera.
My only question to anyone else that did this with the TV and DAB, is where did they locate the 3 aerials?? They are short aerials (maybe 3") with magnetic bases. I tried to locate them on the dash however the reception was terrible, so currently have them running out the side trim and up the A pillar and on the roof. Nobody notices them but I am wary I cant go through a car wash with them!
Post #405786 21st Sep 2016 5:55pm
rnitto
United States
PaulB1976 wrote:
Well.........Its in !
Huge thanks to Master Haylands for this post and to all that contributed to it.
Very pleased with the results, Only problem, Steering wheel buttons are not working so unsure if its a faulty canbus system?
Any ideas ?
Also, have a slight buzz/rumble out of a couple speakers (Guess they are blown), should i upgrade or buy like for like from a breakers?
Anyways, If i can follow these instructions, anyone can !!!! The hardest part really is removing all the trim !
Do you have a link to this unit? Thanks!
Post #417088 8th Dec 2016 2:16am
nip848
http://www.ebay.co.uk/itm/7-Android-5-1-1-...1c77378557
It's got £7 cheaper since I bought it in Spring too. When you buy it if you add in your message its for a RR they can tell you how to get into the settings that change the start up logo to Land Rover as mine was BMW when I got it.
Post #417097 8th Dec 2016 9:21am
rnitto
United States
Ok great, thank you very much! The green looks nice. I just wish it had flat sides and not the curved edges bc they stick out. Im still looking around for the right unit.
Post #417101 8th Dec 2016 9:33am
