![]() | Home > Technical (L322) > LED Sidelights |
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 ![]() ![]() ![]() |
I have just bought and fitted the lamps below, I just wondered if these could possibly run too hot and damage the plastic reflector, anyone have any experience of this??? or thoughts?
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
1 watt of light is 683 lumens, thus a 5 watt wedge bulb producing the specified 50lm is using less than 0.1W of those 5 watts to produce visible light - the remaining 4.9 or so is (broadly) emitted as heat. Assuming the stated 3.08W power consumption of those bulbs is accurate, they don't even draw as much power as a filament bulb would emit as heat, so there should be no need to worry. |
They look ideal to me, can't see why you should have any problems at all. |
markyp Member Since: 05 Feb 2013 Location: essex Posts: 234 ![]() ![]() ![]() |
ive had these in mine for a while now and they have been fine, 2004 vogue
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
I had them on my last L322 without any problems. |
Goldy Member Since: 24 Mar 2016 Location: Bolton Posts: 77 ![]() ![]() ![]() |
How do they look and were they easy to fit?
M4TT53 Member Since: 24 Dec 2016 Location: Devon Posts: 19 ![]() |
Sorry to resurrect an old thread.
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
noticed on my 2007 FF. just ignored it |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35606 ![]() ![]() |
its called hot and cold monitoring.. this can be switched off with a GAP iidtool.. |
Frank Elson Member Since: 20 Feb 2016 Location: Blackburn, Lancashire Posts: 34 ![]() ![]() ![]() |
Yes, mine does it.
