Home > Technical (L322) > suspension on bump stops |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Have you re-enabled the suspension with the iiD and then pressed up on the dash board switch ? 2008 MY Supercharged
4th Apr 2016 5:04am |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 325 |
Hi axle,
4th Apr 2016 5:50am |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
Do you have any error codes on the system?
4th Apr 2016 7:53am |
Have you disconnected the battery for 15 mins, reset all fault codes ?? If not, see if that makes a difference. MY 2010 5.0 SC Galway green and sand interior!!
4th Apr 2016 8:37am |
Wee Jock, only air susp inactive on dash
4th Apr 2016 8:49am |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Hiya,
4th Apr 2016 9:02am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
Have you tried running the engine and doing a full lock to full lock with the steering wheel? |
4th Apr 2016 9:32am |
Did the lock to lock nothing
4th Apr 2016 10:07am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
littlecub, have you done the above suggestions by Simon........ edited for clarification...... ... - .- -. Y. O. L. O. . |
4th Apr 2016 10:08am |
If you have an IID tool you can check tank pressures, pump temperature etc. etc. with live data. You can also force it to run with the IID as that's how I fixed mine which was cutting out with a false over temp reading (damp in the connector). I forget how it's done on the IID but it will come under something like Actuator Tests. |
4th Apr 2016 7:54pm |
Thanks weejock. |
4th Apr 2016 8:29pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
Sounds to me like you haven't re-enabled the EAS with the IID....
4th Apr 2016 8:38pm |
Pulled compressor out this morning and found that one of the smaller airlines wasn't seated properly.
5th Apr 2016 4:52am |
Have a go with the live data see if there are anomalies showing up in the data somewhere. MY 2010 5.0 SC Galway green and sand interior!!
5th Apr 2016 5:52am |
