Home > Technical (L322) > suspension on bump stops
Check the sintered bronze exhaust filter on the compressor , they block easily and stop the car going down . 2008 MY Supercharged
Post #380817 5th Apr 2016 9:41am
Exhaust filter problems are on the later pump from 2005, different on the early ones...
Still worth checking the pipes for collapse or if they have been crushed..
Try to lower it with the IID, if it does then it's probably an EAS ECU problem... Pete
Post #380852 5th Apr 2016 1:18pm
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Went down the shops this morning.
Lowered it 4 times and it did it silently. Very Happy
Even the access button is working again. Laughing
Thanks everyone for the suggestions to get it working again.
cheers
Post #380933 6th Apr 2016 12:14am
