![]() | Home > Maintenance & Mods (L322) > Valley Pan Leak? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8392 ![]() ![]() ![]() |
Pete, if you suspect that the pan is bent, then a generous bead of sealant and torque it to 1/4 of what it should be, let it go off and then torque it down to what they say, that way you make a decent thickness gasket and then put it under compression, rather than just squeezing it all out first go.... |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
Pepi Member Since: 04 May 2015 Location: Doncaster Posts: 125 ![]() ![]() |
Morning all |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
I have ordered all the genuine parts to tackle the valley pan replacement next week from Dan at Duckworths. I will document my entire process as always and make a guide available on here and on my website www.myrangerover.co.uk
11141736175 part number for m60 VP gasket. |
Well onward and downwards.
Because you have 2 adjacent cylinders low I'd suspect head gasket. Compression should go up with oil test if its rings and won't with bad valves or head gasket. Its possible to have 2 cylnders with bad valves but not that often. Here in the U.S there is Thermagasket head gasket sealer. Seen it work very well. I'd spend the $50 and do that first. Then i'd use Restore engine treatment and see if overall compression improves. It also has great reviews and doesn't cost much. Now if you are planning to do timing chains or vanos might as well pull the head and see. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
It does look more like a head gasket blow between cylinders. Are you getting any coolant contamination? Maybe white engine oil? I think you can buy a tool to pressurise the bore, at its top of stroke, through the spark plug, and see it compression-leaking to next bore....I think I was told about this, but might be worth looking for, as it only going to be a special spark plug, with a shraeder valve. But, to get the next bore to be sealed, you would need to have the camshaft off. Or observe the pressure out of inlet/exhaust throat with say fag paper in fingers. (Old school)
That makes sense Pete, that'l be why it's pinking, one cylinder upping the pressure in the other cylinder at the wrong time... result... pinking, will confuse the hell out of the engine ECU as it tries to retard the ignition....
Hi all nocturnal Neddy hear. I am feeling a real donky. I bought it knowing what could be on the cards. Took the gamble and came unstuck. Thought I had got it sorted though. The darn car just gave me long enough to get hooked on it.
I'm not a fan of additives but Thermaseal is an excellent product. Check out Youtube. Look at their web site. No I don't work for them. Seen it work great for a friends Astrovan. But if you are up for the challange of the teardown and the satisfaction of getting through it then go for it.
Hi looks good. How bad was the gasket on you mates Astro? Is it still holding OK and what sort of service has it done since the fix? To
Getting down to the VP is one thing. Removing everything to pull a head is twice that plus. Again if your timing chains and guides are good for now i'd hate to have to pull all that to do a head gasket if there is an alternative. Alusil for the M62. No worries unless the Rover was fed lots of high sulfer fuel. From what i have read - was going to buy a 98 XK8- the rings go on Nikasil or Alusil engines well before the bore gives out ASSUMING it was well cared for.
How did you do the compression check, you should remove all the leads to the plugs, take out one plug at a time, insert the tester and crank it over with a wide open throttle, if you don't have a WOT when testing it could be a long way out, maybe even 30psi....
