![]() | Home > Maintenance & Mods (L322) > Valley Pan Leak? |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
I'm collecting parts list for prep for valley pan repair. Is it necessary to replace the plastic cover that sits on top of the valley pan? Not sure what role it plays. Also is it best to replace the pan with OEM part or can it be resealed. PO tried and looks like failed. Thought that maybe the gasket sealer is of a special formula. |
Thats what I feel. But if someone said "yeah I've used XYZ sealer and it worked for 150k miles" I'd try it. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I have this job to do when I get a chance, - I'm going to reseal it with black RTV (place a bead, allow to set and then reattach) and change the inlet mani seals, and probably remove water pump and reseal the front to back water pipe seals, (o rings) and the two rear gaskets on the y piece, and the infamous soft heater hoses. Also gonna swap out the thermostat, for the lower temp option. as these jobs are all very easy at that opportunity. I have all the gaskets and seals, just need a day off!
I remember watching this video before buying the Rover in prep for the repairs I may need to do. Clearly not a Fullfat but maybe even easier on ours. It answered 3 questions I had but leaves one important one unanswered and that is how long did his repair last. |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
what will make it a little more difficult on ours, is reaching the back of the engine. It's a bit of a stretch unless you're 8ft tall. |
No its easier. The bigger cabin air filter box removed gives you lots of space. Reach is no problem when you are lying in the engine bay. I will say its not a good idea to do this with the nose up on a 25 degree hill. I need to lose 10 lbs or 20 years. |
it helps if you make a platform next to the car. Boxes with a plank across them or something. |
http://www.fullfatrr.com/forum/topic6714.h...ey+coolant
My valley pan leak seems to be slow enough to wait for spring do fix. But in my search to find the best way to seal it I found a BMW thread that said the the M60 valley pan is identical and the earlier ones use a separate green gasket that seals better than the current system and it costs $11. Anyone have experience with this? Thanks |
Pepi Member Since: 04 May 2015 Location: Doncaster Posts: 125 ![]() ![]() |
Did anyone come up with a sources of the "Green" valley pan gasket. Or a part number. Eddie the eagle watch out 👀 |
Realoem.com doesnt list it separate because the new pan/gasket replaced the old system. I could have sworn i found it somewhere. Ill keep looking. That being said it doesn't seem to be my valley pan that is leaking and the PO using a silver/gray RTV fix is holding for 20k miles now. |
Well found the BMW part number but it would seem at first glance that it is only from the states or Germany. Any one know home grown UK supplier.
I have a theory why BMW changed from separate gasket to gasket/pan combo. The pan is not very robust and in reusing it you risk reusing a pan that is warped and will not hold a seal. By having the pan/gasket set BMW avoids admitting its pan was underengineered and that it couldn't handle modestly improper or over torquing. Since the new upgraded pan has the RTV gasket attached one can't say RTV doesn't work assuming its the right RTV. I've read some people like using the M60 fiber/sealant gasket and claims it lasts longer. It may even be more forgiving with improper torquing. Just a theory. |
Go on you got me!
