Home > Maintenance & Mods (L322) > Valley Pan Leak? |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 |
Pete is right. I was thinking coolant because of the VP leak. If the head gasket leak is only between cylinders i don't know if they make a sealant for that. Thermagasket not Thermaseal. RXAUTO.com is the site. Contact them and see what they say.
5th Apr 2016 3:19pm |
Pepi Member Since: 04 May 2015 Location: Doncaster Posts: 125 |
When testing the compressions I took the fuel pump fuse out. Removed all the plugs so I could get a bench mark uniform turn over speed. Took each pot in turn with the accellorator peddle depressed I let the engine do ten ful revolutions on each test. I am not sure that that will open the throtle, does it?! Or to do this would I have to manually prop it open.
5th Apr 2016 3:21pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
Hi Pepi, I'm in the middle of doing my valley pan seal.
1st May 2016 12:11pm |
this post is from page 2 , however this gasket is for the old fashioned flat valley pan, our RR one, is stepped, so this gasket does NOT fit. i recommend, part number LCW000010 valley pan cover, with the factory bead of sealand applied. i tried the reseal method.., it lasted 1 month. -even with a low temp thermostat fitted. |
29th Jul 2016 1:04pm |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 |
Does anybody have the part numbers for all the pipes at the back? Also the gaskets for the coolant manifold? I'm going to change these on mine while I'm doing the valley pan. 2004 RR 4.4 V8 Autobiography |
30th Jul 2016 11:19am |
Unnecessary quote removed
6th Aug 2016 7:18pm |
When I first did my repair, I did let the RTV go off overnight. It was 'hard' and did not burst or squish soft unhardened RTV out at all. I carefully placed it and tightened it down. It did hold for about 3 weeks.
6th Aug 2016 10:04pm |
The PO on mine used a Permatex Gray. It has been holding. I know it is not the same pressures but on my BMW 325 valve cover I had a of a time getting it to not leak. This last time I was sure to clean everything off the head side and wiped it down with acetone. I also cleaned up the inner valve cover surface and wiped it down with acetone. I applied the black RTV in a very thin layer with my finger to both surfaces and let sit about 2 hours before adding the gasket and setting torque. Let it set 24 hours. No more leak.
6th Aug 2016 10:33pm |
mattyp Member Since: 30 Jul 2016 Location: Clacton On Sea, Essex Posts: 101 |
Do you have a link for the pattern part cover ? |
7th Aug 2016 9:40am |
Hi folks
7th Aug 2016 10:46am |
Ouch! Great pics and info though. Are you starting a Gofundme page? |
7th Aug 2016 12:48pm |
This is the same as what I used. Either search online for LCW000010 or use a link like this...
7th Aug 2016 3:38pm |
7th Aug 2016 3:50pm |
Thank you, mine has stared to leak so I'll buy this, do you have a link for the inlet manifold gaskets ? |
7th Aug 2016 5:59pm |
