![]() | Home > In Car Electronics (L322) > L322 radio problem |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Don't know much about the old style head units but the newer 07MY on are run off a plastic fibre optic network. If one of the components goes down (mine had a drowned Bluetooth unit) then it kills the entire network.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Won't be a MOST system.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3259 ![]() ![]() ![]() |
Depends when in 2004. If late then could be MY2005 with MOST. (September build onwards). John
Daverr Member Since: 20 Mar 2016 Location: Nottingham Posts: 3 ![]() ![]() ![]() |
It's early 04 tried battery disconnect and fuses 8 and 48? Under cd changer just no power on light on head unit |
Are there any more inline fuses or internals on amp? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8541 ![]() ![]() ![]() |
No there aren't, have you followed the proper battery disconnection procedure, it's in the WIKI..
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35649 ![]() ![]() |
as above,
There's a 10A fuse in the top of the radio BM54 unit. Remove the large connector plug from the unit and it can be seen underneath. No reason a flat battery should cause it to blow but you never know. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
My 2002 radio one day didn't work. I suffered for a month, and eventually, tried the battery disconnect procedure, and now it's working. But the cd is dead. I can live with that. Sort of scared to fiddle again, in case it's screws up. |
