Home > In Car Electronics (L322) > L322 radio problem
Daverr
United Kingdom 2004 Range Rover Vogue Td6 Buckingham Blue
L322 radio problem
Hi all, thanks for the add, need some advice please, l322 04 td6, radio problem, hat flat battery, put leads on and jump started, fired up 1st turn, no problem,but have lost audio no Amber power light on head unit,sat nav works but no sound all computer functions ok screen is all right checked fuses under cd changer all ok boot compartment is dry anyone got any further ideas please?
Post #378533 20th Mar 2016 6:19pm
sako243
Don't know much about the old style head units but the newer 07MY on are run off a plastic fibre optic network. If one of the components goes down (mine had a drowned Bluetooth unit) then it kills the entire network.
If you do have the fibres then you can unplug them and look into the fibre to see if there is any light.
Note there'd be a pair, one is transmit and the other is receive so light may only come out of one. Ed
Post #378551 20th Mar 2016 7:16pm
Won't be a MOST system.
Suggest do some fault finding, check all related fuses, dive into the left rear boot space and check and reseat all connections on the AV kit. Worth also a battery disconnect procedure. .
Post #378554 20th Mar 2016 7:26pm
Weegie
Depends when in 2004. If late then could be MY2005 with MOST. (September build onwards). John
GAP iiD BT
Post #378558 20th Mar 2016 7:47pm
Daverr
It's early 04 tried battery disconnect and fuses 8 and 48? Under cd changer just no power on light on head unit
Post #378564 20th Mar 2016 8:13pm
Daverr
Are there any more inline fuses or internals on amp?
Post #378565 20th Mar 2016 8:16pm
No there aren't, have you followed the proper battery disconnection procedure, it's in the WIKI..
Link below fullfatrr.com top right of page... Pete
Post #378581 20th Mar 2016 9:47pm
as above,
proper dis-connection and a properly charged battery.. ... - .- -.
Post #378582 20th Mar 2016 9:55pm
There's a 10A fuse in the top of the radio BM54 unit. Remove the large connector plug from the unit and it can be seen underneath. No reason a flat battery should cause it to blow but you never know.
Post #378586 20th Mar 2016 10:16pm
johnboyairey
My 2002 radio one day didn't work. I suffered for a month, and eventually, tried the battery disconnect procedure, and now it's working. But the cd is dead. I can live with that. Sort of scared to fiddle again, in case it's screws up.
Post #378589 20th Mar 2016 10:31pm
